查看: 3521|回复: 0
solidworks工业设计师云:导出数据到solidworks
发表于 2016-4-7 19:12:38 | 显示全部楼层 |阅读模式
8 r8 l3 r( V: R# H2 F# I4 W. R2 J5 \4 \. S
有关solidworks工业设计请先读以下帖子:
. _& T& |0 e8 y! j有关Solidworks 工业设计的消息
9 G1 r! a+ e7 r0 W$ q' V& @( Phttp://www.cmiw.cn/forum.php?mod=viewthread&tid=388386$ q7 \' P: f- a3 W0 X; M
Solidworks工业设计云30条技术要点
4 |% O' v; n: U3 |8 f& Dhttp://www.cmiw.cn/forum.php?mod=viewthread&tid=388842( O- }3 u, i4 S  @# x$ r& E
7 J/ o7 ^0 ~# H$ }3 }: j现在solidworks工业设计云已更名为solidworks工业设计师。
/ I! t" r$ }( }" g( Z2 a4 q/ e- L7 `4 B! }* I4 D
The first of which was how to export SOLIDWORKS Industrial Designer to SOLIDWORKS because as awesome a tool as SOLIDWORKS Industrial Designer is, it is far, far better if I can harness the awesome power of SOLIDWORKS alongside it. However, exporting the file wasn’t as obvious as I’d initially thought. But, after some experimentation (which I hope to save you the effort), I was able to figure it out. Here’s how you do it。5 X) X( q8 U8 Z0 _
solidworks工业设计师是个好工具
7 ~% s2 o  Y# s0 aFirstly, it matters where on the Export menu you click. I had thought that SOLIDWORKS Industrial Designer  would be like SOLIDWORKS where if I click on the arrow beside the word it would produce the same result as clicking on the word itself. Not so.: @1 f1 n5 Z0 h- d- f( v% {
如果你以为是点击export这个单词旁的箭头,那就错了。
. S; Q) q7 B. y. ]. b; p# q. RClick on the word “Export,” not on the arrow beside it.After I figured this bit out, it was completely intuitive from here on in. Step 2 was to give it a filename
2 O# n- i' i, [1 h* i要单击export+ l+ Z) p8 Y8 a- E6 X4 l4 e
( m5 @( }( Q3 j) F* q% v0 @. ?9 O! H) u  j. y: Z
It turns out I can export to several formats including .3DXML, .AMF, .STL, VRML (.WRL), and our good friends STEP and IGES. There’s also an option to export to SOLIDWORKS, although it exports it as a .SLDXML file, which SOLIDWORKS 2015 and 2016 have no problems importing whatsoever. It even exports to CATIA. Naturally, I chose the .SLDXML file so I could test it out.5 }. R- _6 s9 o% n
1 x: g- E  H1 j+ ~! ~
; ]6 I: m. b" t% o' R不管什么格式,导出到solidworks的是一个坨,因为solidworks工业设计师使用的是CATIA的图形内核。
: Q, {  p/ F; j" \0 @4 b$ z6 g, H+ m6 i  T+ a( f. O
" D9 U! E( e; }
您需要 登录 才可以下载或查看,没有账号?注册会员
GMT+8, 2025-8-18 08:35 , Processed in 0.083001 second(s), 20 queries , Gzip On.
