程序如下:6 ~) a4 U. V3 Y2 ~: N
O9010(P0 WORK DEPH & ANGLE CYCLE G112-6050);(DATE 080197);(G65 P9010 T、B、S、Q、-ACR);(A=ANGLE,C=CORNER-RADIVS);G90G10L2P0Z0;#27=4003(G90-G91);IF[#13EQ#0]GOTO30000 (M98-M198);IF[#20EQ#0]GOTO30000 (T=TOP);IF[#2EQ#0]GOTO30000 (B=BOTTOM);IF[#2032LT#3]GOTO30000 (D<C);IF[#20LT#2]GOTO30000 (T<B);IF[#17EQ#0]GOTO30000 (Q);IF[#19EQ#0]GOTO30000 (S=SUB PRO);IF[#19NE#0]GOTO1001 (R POINT);#18=100;N1001;#30=[#2032-+[TAN[[90-/2]×#3];#17=ABS[#17];#33=#20[SET Z];#31=#2032 (RESTORE);#14=0 (SET W);N10;#14=#14+#17;#33=#33-#17;IF[#33GT#2]GOTO11;#33=#2;#14=ABS[#2-#20];N11;IF[#1EQ#0]GOTO113;#32=[TAN[#1]×[ABS[#2--[TAN[#1]×#14];#2032=#30-#32;N113;G90G10L2P0Z#33;D32;M#13 P#19 (SUB PRO);IF[#33EQ#2]GOTO99;GOTO10;N3000#3000=140 (DATA ERROR);N3001#3000=141 (#T LT #B);N99#2032=#31 (RESET);#502=#33 (RESTORE Z);G90G10L2P0Z0;G90G00Z[ABS[#18]];G#27;M99; 我不懂宏程序,就是抄下来的,请帮我看看有没有什么错误,谢谢了
8 A1 h# b- f: q, g( i |
