查看: 2788|回复: 1
编了个矩形平面加工小程序,请朋友指教
发表于 2008-8-26 12:39:24 | 显示全部楼层 |阅读模式
编了个矩形平面加工小程序,请朋友指教
  \- c: _0 c9 a# x& i/ F;释意:SHANGMIAN=加工前工件上面最高点坐标(应去除)! P; k7 @: _4 _& m+ k
;XIAMIAN=加工后工件上面坐标(加工所得)" a5 r+ n  F3 Y6 t* R. ]: J- h
工件坐标系原点在矩形左下角' j$ r8 ?5 Y( M0 s& b; x% R  h
PROC PINGMIAN(REAL CHANG,REAL KUAN,REAL FANHUI,REAL ANJU_Y,REAL ANJU_Z,REAL SHANGMIAN,REAL XIAMIAN,REAL YULIANG,REAL CHISHEN,REAL CHIKUAN,REAL JINGEI_SHEN,REAL JINGEI_PING,REAL YICHUZ,REAL YICHUY,REAL YI_X,REAL YI_Y,REAL ZHUANJIAO)1 y) l( @5 I- M! _- T# h4 I
DEF REAL QUCHU4 I- d: N* e2 {6 b  u
DEF INT DAOSHU_SHEN6 {; v* l+ d! e8 A# k# z# l- ~
DEF INT DAOSHU_PING. W' M2 D' s5 q- c; ?5 y- w
DEF REAL QIDAO_X
0 |& L7 l! A* P9 S1 QDEF REAL ZHUDAO_X+ l" L5 W3 u& X
DEF REAL T_R
# ]+ Y0 K7 s; n( QDEF REAL KUAN_
" R& B# S. Y! D6 jDEF INT JISHU_SHEN,JISHU_PING/ ]! Q4 X+ I* K/ Z& V: I2 `! f- K) N0 I% D
DEF FRAME FRA_
! N7 M" P- {6 Q9 n; K) f1 g3 EDEF INT _G6,_G14,_G15,_G108 e7 ^5 x9 M, U/ v0 {$ r
DEF REAL ZHONG
4 |9 Y( R; n9 {- z% _+ g1 J* aIF $P_S==0 GOTOF AL1+ ]$ v8 n3 E# u
IF $P_TOOL==0 GOTOF AL2
# r7 q5 x, `) W& V: M$ R;-----------------------------------------------------
% @/ J. c. m' v; [. L9 m( mT_R=$TC_DP6[$P_TOOLNO,$P_TOOL]) [- M5 F: d  }4 N" H
;------------------------------------------------------( V8 C% o! a$ b
CHANG=ABS(CHANG); C" T, X* ^+ s7 ]
KUAN=ABS(KUAN)- j( e+ e  U6 l6 T* ^9 Z) Y7 Q
FANHUI=ABS(FANHUI)
* V5 L8 C$ ~0 `  o0 z( tANJU_Y=ABS(ANJU_Y)
- b  W1 h1 K3 e; H" |/ IANJU_Z=ABS(ANJU_Z)* r* h  z0 s. K* q1 S3 j9 m
YULIANG=ABS(YULIANG)
, V0 p/ m- d/ I! Q5 p+ ]CHISHEN=ABS(CHISHEN)
( c; P4 n7 u$ ^' qCHIKUAN=ABS(CHIKUAN)
0 \6 X- p. w" mYICHUZ=ABS(YICHUZ)
1 ]9 P  j9 h6 s+ [$ ZYICHUY=ABS(YICHUY)
" r* ]7 d: X0 n8 g; ?# L8 mSTOPRE
! r$ s- M3 f& q' O* Y;------------------------------------------------------8 ?& |: {5 E: B" K, r
QUCHU=SHANGMIAN-XIAMIAN-YULIANG
# _4 k+ I9 x- O  ~0 n: a+ f* ]. ]IF (SHANGMIAN-XIAMIAN)<YULIANG GOTOF AL36 ]. Q8 J, W* A! s9 |* J
DAOSHU_SHEN=TRUNC(QUCHU/CHISHEN)! Y1 i* j( k. H/ W& I2 d
STOPRE) E, `. `% d9 P0 f- z0 n7 |; D( R
IF DAOSHU_SHEN<(QUCHU/CHISHEN)5 K) m! y2 s% k, p( N
DAOSHU_SHEN=DAOSHU_SHEN+1
: S0 U8 p% G. r# p9 c; jCHISHEN=QUCHU/DAOSHU_SHEN* Q9 n" @( h, d! w6 D
ENDIF+ ^) ]5 w7 C6 P: R/ s( W
- @- o6 q5 O+ U  Q+ K1 m# XKUAN_=KUAN+2*ANJU_Y
+ X1 g6 b8 y+ B/ _! ]: w4 CDAOSHU_PING=TRUNC(KUAN_/CHIKUAN)7 g# h- \; _/ g: j; ]% l! K/ h$ G4 G
STOPRE
5 L  H$ `. |1 F  ?IF DAOSHU_PING<(KUAN_/CHIKUAN), H% R/ z1 I2 C
DAOSHU_PING=DAOSHU_PING+1
7 G7 C! X: m6 u7 CCHIKUAN=KUAN_/DAOSHU_PING  O: b, C. W6 R# Y) F; ~
ENDIF$ O0 E2 O, }/ D! w8 N
;-----------------------------------------------------/ H* `) F* f5 T* {6 a1 ?) w
ZHONG=CHANG/26 F8 D; Y9 {) |: y2 ?' d4 [( j7 p
QIDAO_X=T_R-YICHUZ
+ E' N- D) Y6 O# C* u, IZHUDAO_X=CHANG+YICHUY-T_R" X$ T/ h; P" n( m. m
: e5 |. V7 j) a" J* r- o- x4 Y_G6=$P_GG[6]
+ \, S6 u4 n( J0 E1 lIF _G6<>1 GOTOF AL4: I5 r' \- T: T, `
;-----------------------------------------------------. q( D& X" U: |/ P4 C3 X! |
_G10=$P_GG[10]( h; X8 o( |! W- O7 }& q! k
_G14=$P_GG[14]5 R9 b" S) R# b. |& ]! ^7 g
_G15=$PGG[15]& s' [" z  S9 z* V
FRA_=$P_PFRAME& ~; s. T2 a0 ]1 b, d
" x" S2 \4 _$ E- jG645 d2 ?. O+ |( G$ D
G90 G94
& M' v8 ~3 j. q$P_PFRAME=FRA_:CTRANS(X,YI_X,Y,YI_Y):CROT(Z,ZHUANJIAO)4 w! j/ m2 ?; S/ B# w
6 t$ N1 F8 x" n" m4 P3 S* ]! BSTOPRE! T/ i& ?- o( k9 ?3 A! W5 M, J
FOR JISHU_SHEN=1 TO DAOSHU_SHEN1 A- e8 t8 v# X$ l% H( @! r
G0 Z=SHANGMIAN+FANHUI-CHISHEN*(JISHU_SHEN-1)
3 P6 [3 f9 |- d# J0 a& _* w5 M& BX=QIDAO_X Y=-ANJU_Y-T_R4 s* g0 Q9 a6 p  z. C
Z=SHANGMIAN+ANJU_Z-CHISHEN*(JISHU_SHEN-1)
- n; T- ?( b8 ?G1 F=JINGEI_SHEN Z=SHANGMIAN-CHISHEN*JISHU_SHEN2 l4 A  X7 b, I$ \/ i* s  ^
FOR JISHU_PING=1 TO DAOSHU_PING
  m. u/ l6 s3 JF=JINGEI_PING Y=JISHU_PING*CHIKUAN-ANJu_Y-T_R
) r' ~2 m2 b, W1 g* Y/ p# bIF $AA_IW[AX1]<ZHONG
5 f$ t5 P) g! a4 \) ]X=ZHUDAO_X" u, x6 h( N. |+ }0 [' a! P
ELSE8 Q8 L$ }3 Y/ ~; B+ [
X=QIDAO_X
+ p5 U  \" P- g3 ]* ^( BENDIF* B" y8 `1 |! D1 L" B
ENDFOR' M5 I. q- V% _2 V, t! _4 m$ U
ENDFOR
' k, B, Q. ~% gG0 Z=SHANGMIAN+FANHUI
/ ?) W$ k5 D2 r4 f+ `; N. nSTOPRE( c+ d( Y  D4 v$ }3 Z$ j' b, d
;----------------------------------------------------: x5 a0 c$ A9 s" ]7 n: Y
G[10]=_G10
! k! ]+ W0 a. K. mG[14]=_G14
4 {, t9 X+ s, P$ eG[15]=_G15
1 y) @$ Y6 U/ e, `' ?4 j' N$P_PFRAME=FRA_& r' j1 k/ w; O: b7 A* |5 y
STOPRE5 S7 ^0 S5 X3 J7 w0 F! B7 X& S$ Y4 a
M17
! j+ L1 l( ~9 b" _AL1:MSG("S=0!")* N% {/ a0 K7 `$ B7 `( f" R
M0/ z9 A5 d+ O( ~& |2 b  P
M17
+ h4 |8 c6 ?) r, hAL2:MSG("D CUO WU")
; u5 ?" h0 t- v0 f: _M03 ^% `. q& @7 Y% A0 N
M17( s% _. T! m1 _5 C; l3 x* F  G
AL3:MSG("SHU JU CUO WU")
% C% }: }) E& x! `M0
9 q, I  ^5 C% }' `7 q/ w6 c* }M17
& w( \, T1 S; S4 h& QAL4:MSG("XUAN ZE G17")
) w8 u6 p  R) \2 X& I4 Z4 CM07 G  ]( R* G0 Q: c
M17
 楼主| 发表于 2008-8-26 12:41:35 | 显示全部楼层
西门子840D系统
GMT+8, 2025-8-15 21:19 , Processed in 0.072051 second(s), 14 queries , Gzip On.
