楼主: 学习进行时
20多岁的人对未来都会有恐惧感 吗?
发表于 2016-3-22 15:32:23 | 显示全部楼层
同感,还好你有老板支持你做,坚持下去也可以的
发表于 2016-3-22 16:49:53 | 显示全部楼层
共勉、、、
发表于 2016-3-23 11:41:30 | 显示全部楼层
说实话,有点恐惧
发表于 2016-3-23 16:33:59 | 显示全部楼层
楼主和现在我很像!共勉!有什么问题可以多多交流!
发表于 2016-3-23 21:38:09 | 显示全部楼层
迈不过的是坎,迈过去了是门。有点鸡汤,但就是这个意思
发表于 2016-3-24 06:28:59 | 显示全部楼层
拿两张A4的纸,一张写保持现状的好跟坏,另一张写改变的好跟坏。不要着急,多想想,一个星期做出一版,然后跟你觉得有经验的人讨论,总之一个月内做出最终版。然后自己衡量吧,适合自己的才是最好的。人生在世不如意十之八九。
发表于 2016-3-24 06:39:42 | 显示全部楼层
/ K# K% P$ [% i4 m' E2 Z# N# I2 ?5 V/ W9 v) d: |+ L" x
给一个外国人的关于抉择的建议,英语不难,尝试自己去看懂吧$ l4 ^5 `& K: u
Firstly, recognise any fear you have related to the decision. Fear of failure, of what others think, of hardship. Fear is almost completely always overrated - it evolved in a time when sabre toothed tigers could dine on our bones and when asking a pretty villager out could get you killed by her father's tribe. Nowadays the downside for most actions is negligible but our instincts are 40,000 years behind. So fight hard to identify and ignore your fear." F, I8 N* G6 \
1 s! _8 L; F* R/ E6 o( ~" LSecondly, make sure you have enough information but not too much. Colin Powell popularised a rule here - aim for between 40% - 70% of the information you need to make a decision. Too little and you don't know what you're doing. But crucially - and often overlooked - too much and you're wasting time and someone else may beat you to it. Paralysis is a decision too, albeit an awful one.  : M: Z1 H0 [+ i) u/ d
5 L; |' K6 r. Y& X; p! |
Thirdly, once you've thought it out - trust your gut. If you're not sure, find a coin and assign heads to one option, and tails to another. Flip the coin. Now, how do you feel about the choice that was made? Whether you feel relieved or horrified will tell you what your instincts know.  _: t" i) d- U
, @6 V" {! u3 e3 d! P1 D: _
Finally, do it. Most people fail at this step; don't be one of them. Good luck.: h* t0 X$ Z$ I+ @4 b8 O
摘自 https://www.quora.com/How-should-I-go-about-making-a-hard-life-decision     时间 23/03/16
发表于 2016-3-24 13:37:56 | 显示全部楼层
有的,但越恐惧就越要努力
GMT+8, 2025-9-10 23:59 , Processed in 0.062995 second(s), 12 queries , Gzip On.
