楼主 |
发表于 2006-5-23 18:03:33
显示全部楼层
Re: 请教怎么用autocad 画渐开线!
2 i. ~6 @ O/ p" B
(defun C:jkx ()
: R3 R1 f' x% C$ ?! u$ k0 C(setq pi1 (/ pi 180))
+ w! w& m0 x7 }+ I/ {+ X% e' c3 b(setq po0 (getpoint " \n 请输入中心点:"))7 d5 |% ^; _& T% q' m
(if (= po0 nil)) f% E, K% x, {& J9 O4 p
(setq po0 (list 0 0 0))
3 F* f& c6 X. N2 u)
% N+ ?" @6 ~) L! b(SETQ d (GETREAL "\n 请输入分度圆直径:"))2 U' I9 Z( f9 m3 S! w& A
(if (= d nil)
@: i$ o/ Q! j3 g* s+ D(setq d 100)
: n( q+ M2 c7 U, J1 p- f8 K)
. f/ A" X9 D9 Z9 u3 O(setq step (getreal "\n 渐开线精细度(0<精细度<=10):")) q2 @) I: K: W
(if (= step nil); s$ Q( ]5 c y$ L
(setq step 1)
5 K1 [2 k! h6 _# D* D9 y) B)
1 k% C! @6 P4 Z7 c3 R1 a! V(setq rd (/ d 2))
% k/ F% t( d, e) ](setq os (getver "osmode"))& J! B# r4 g& M- H, t- U
(setvar "osmode" 0)
5 S1 F: m6 N3 _, v(command "UCS" "OR" po0)
3 v, ?) x- e. [(command "CIRCLE" "0,0" rd)' z W/ `( i' g
(SETQ R (* rd (COS (* PI1 20)))) ;标准齿轮分度圆的压力角为20度
7 F1 ~! I' ?2 C% h(SETQ ST 0)
# F7 {5 ?3 H* G) s3 R(SETQ STR (* PI1 ST))
9 o3 ]1 d; b; ` L/ t" }(SETQ X (* R (+ (COS STR) (* STR (SIN STR)))))6 R' D) c) ?& \
(SETQ Y (* R (- (SIN STR) (* STR (COS STR)))))' H+ C! }! F6 H* ~# d3 U
(SETQ XY (LIST X Y))
, W& n) |' U$ q(COMMAND "PLINE" XY)
6 E1 ~$ D6 ?# V" I, ]8 J(SETQ ST (+ st step))- p* x$ u) S5 [3 `! I
(WHILE (<= ST 80) ;齿轮上的渐开线压力角不会超过80度
( j; _2 l- l! V) f3 U2 B7 \4 f( v4 d(SETQ STR (* PI1 ST))/ e- U. A. B; G
(SETQ X (* R (+ (COS STR) (* STR (SIN STR)))))! y) l, w6 @! W6 B
( J7 z/ ~5 X3 @( P' u/ M- n [(SETQ XY (LIST X Y))3 e, d) D- ~, X m
(COMMAND XY)* m1 R- _ o7 ?! h
/ ^% o) W, ~* c: r1 S) n)! h+ X& I9 M) W6 ^
(command "")
: C9 x+ I* r% C. f4 \5 [/ r B(setvar "osmode" os)
. n, Q" Y; b2 W! z! C8 G6 S(command "UCS" "P")7 L7 h$ ~( D2 d9 C% |
4 g3 Z# T: ~5 M7 A7 f' E2 R. r有人用autolisp写的,不知道怎么用,能给点提示吗? |
