In 2015x, a new feature was added to the command manager in SolidWorks which may be my favorite add on yet; you are able to promote! For those of you who have never used Enovia before (or those that have and know this all too well), in previous versions the user was required to promote outside of SolidWorks. This meant checking out you part, doing your engineering change, checking it back in, going into the web, locating the part again, go to the lifecycle tab, ad promote the part to the next step. In 2015x, Dassault Systemes has now added that functionality directly into the command manager in SolidWorks. I cuts out a chunk of time when promoting a single object. That being said, it only capable of doing that. PROMOTING ONE OBJECT AT A TIME. Be wary of this, it only promotes whatever windows is currently active. If you have an assembly, and have one specific part open, it will only promote that one part. Other than that, this change is greatly welcomed!
. M. m9 |% v/ W) r: D) [Enovia v6 2015的新功能之一4 z& i9 i+ r8 q, v' O; X* q0 e
以前的版本在使用检出命令时,通常是在solidworks之外,单独弹出的网页页面,enovia使用浏览器界面。现在,检出命令被集成在solidworks command 工具栏上。/ \3 Z9 ]% n( O3 f" t
0 `# [5 _) ]8 j P# C+ b2 Q9 E
/ ^$ Y; ^9 D, L+ y/ j" m- s
" e7 }7 Z3 z; y4 B9 ^) SExpanded option in a RMB may not sound like a big change, but this little detail can play a pivotal in your everyday user's life. Having more options is always a nice thing. In this case, Enovia has introduced a few new options into the RMB click, but only in a few selected areas. In the past, users where not able to right click on parts in the Where Used and Contains tabs and get many options. It would require the user to either navigate to that part within that window or open the part in a new window all together. When you are digging for a part somewhere deep down in a large assembly, this can be frustrating, typically resulting in numerous windows open or losing your starting point. Now, users can have all the usual RMB options directly from those tabs, making functionality easier for the users. Great example of little details that make a big difference! , V, J" K1 U' M- A) I
新选项加入到windows资源管理器中3 y. X5 F" u( U3 l4 J
' t- U& _. N) F# F8 Y- x( L/ J/ n+ n
