查看: 19661|回复: 3
请问AISI 1045钢与国内的哪种钢材接近对应
发表于 2006-12-20 16:17:25 | 显示全部楼层 |阅读模式
发表于 2006-12-20 19:10:05 | 显示全部楼层
Re: 请问AISI 1045钢与国内的哪种钢材接近对应
AISI 1045   l. S3 i. x: }3 x- z
/ c2 I& C5 O# N* u( o, t
6 v5 O: E( }5 ^, Y4 }8 cCategory  Steel
  P: s8 N1 w# V! \Class  Carbon steel
: w$ k1 W' Z! W. {+ J- h1 k/ ]" L* RType  Standard 9 q+ x! [: G: U4 j+ o  L8 [
Designations  France: AFNOR XC 42 TS , AFNOR XC 45 , AFNOR XC 48 , AFNOR XC42
% D4 F% e* N$ HGermany: DIN 1.1191
+ H3 z0 q% r+ g  j6 t0 xJapan: JIS S 45C , JIS S 48 C / Z3 @+ k5 c! t8 m
Sweden: SS 1672
+ g1 U6 G$ N5 y) |3 N2 EUnited States: ASTM A29 , ASTM A510 , ASTM A519 , ASTM A576 , ASTM A682 , FED QQ-S-635 (C1045) , FED QQ-S-700 (1045) , SAE J403 , SAE J412 , SAE J414 , UNS G10450  2 F3 d7 h$ g8 z, e' s
* V* k- _+ T7 p% mComposition
+ u; B' I- b2 s4 V , |% C. Y( a5 {' K/ }9 _2 r
/ |* z; [$ V; _1 @* T  {4 _0 ~Element  Weight %
; u5 E; f9 a& zC  0.43-0.50
& @- b+ k; ~% g! ]3 L/ BMn  0.60-0.90  / I" E8 T! W; t; h3 N+ f# {
P  0.04 (max)  0 E+ v2 O2 i3 Z7 q. O
S  0.05 (max)  4 K5 @% z( e: {9 P
, Y9 D. v" j' R" r$ g. r
+ u6 ?# I4 n' w& C! u) ]3 m# l
Mechanical Properties 4 u' f; v2 O/ I2 o5 R. u7 d
! A' N9 b7 g" \2 J  _
5 F$ q0 s2 {0 t5 K: m9 s3 b
Properties  Conditions  & f! a! e  B" H* ?
T (°C) Treatment ' z+ `2 F+ r& f5 k! N+ B
Density (×1000 kg/m3) 7.7-8.03  25
9 ?$ ?. P# L& o/ N7 R4 P! b; N( bPoisson's Ratio 0.27-0.30 25
) t. C9 ?/ ?0 Q! B! l' ^0 JElastic Modulus (GPa) 190-210  25
" ]- ^% |- `/ O( ^% eTensile Strength (Mpa) 585  25  cold drawn, annealed (round bar (16-22 mm)) more
  k+ v5 V2 n/ wYield Strength (Mpa) 505  ' i8 K7 h9 P# d3 [
Elongation (%) 12
5 V! y) C/ d. w+ f" t$ v! N( ]Reduction in Area (%) 45  9 b' S5 A/ l. X8 _/ \3 M
Hardness (HB) 170  25  cold drawn, annealed (round bar (19-32 mm)) more 5 y7 V' P% ~* r: P4 _
# [9 U+ C, G2 V3 q) s3 N0 `
发表于 2006-12-20 19:12:31 | 显示全部楼层
45钢
 楼主| 发表于 2006-12-20 21:21:44 | 显示全部楼层
VERY THANKS!
GMT+8, 2025-8-21 04:02 , Processed in 0.060791 second(s), 14 queries , Gzip On.
