查看: 2280|回复: 3
菜单的创建
发表于 2011-5-25 11:41:07 | 显示全部楼层 |阅读模式
Module Module1+ ?) d+ h, ^2 _& G0 G
    Public Acadapp As AutoCAD.AcadApplication
4 I: _% L1 C! U8 k! E    Sub 连接AutoCAD()2 z9 B1 E. Q0 N
        On Error Resume Next2 |2 n7 k3 a+ G; L
        Acadapp = GetObject(, "AutoCAD.Application")3 v8 E& j5 X5 q2 \2 t; Z9 \* \
        If Err.Number Then
9 e# Y& q4 ?- ?; }% L6 e6 c            Err.Clear()% U% i. Q. a  c* h7 I4 \" d6 C
            Acadapp = CreateObject("AutoCAD.Application")
+ z4 D/ X' Y- {* [/ h            If Err.Number Then
& @& ^0 e2 P- b  _- H4 E4 X                MsgBox("不能运行AutoCAD,请检查是否安装了AutoCAD")
! ?, u" z# ^" V$ b                Exit Sub
/ @4 P" f) m( @6 e% r' {0 \- L            End If9 v+ u: J7 [$ Y2 G5 H6 C" f3 |. j
        End If  v& i3 j" ^  d# Z7 r, v
        Acadapp.Visible = True '界面可视
6 q9 X* v+ y& [; o/ R% n1 j5 R" \        Acadapp.WindowState = AutoCAD.AcWindowState.acMax '界面最大化
# O; y0 G( I( f        AppActivate(Acadapp.Caption) '显示AutoCAD界面4 w% G+ q' p" C! V- K0 z8 L
    End Sub
# c- F' p% f- l1 C$ a    Sub main()
2 `9 I9 U3 U4 Q5 ^3 Y        Call 连接AutoCAD()
* L6 u* W" ^& ?. e* e2 y- d        Dim currMenuGroup As AutoCAD.AcadMenuGroup8 a- I& w* f% h4 [) O, u6 ^5 @7 g
        currMenuGroup = Acadapp.Application.MenuGroups.Item(0)0 W( n( Y/ C. Q2 L- X* e
        '创建新菜单
& y5 g& Z# \) P! n. z% U        Dim NewMenu As AutoCAD.AcadPopupMenu
6 G0 [9 Q# j: c2 v7 ]        NewMenu = currMenuGroup.Menus.Add("个性化菜单项(&B)")! e( A, e; N. F* r
        '注意,若AutoCAD菜单条已有一个同名菜单,则会报错。
6 J  ]1 p, p, e        '在新菜单上添加菜单项
5 [$ c$ i* Y: W" H" Y+ }9 y        Dim newMenuItem1 As AutoCAD.AcadPopupMenuItem  D5 h8 ^: ]3 b& [+ Z  T( \
        Dim newMenuItem2 As AutoCAD.AcadPopupMenuItem" {/ F0 W0 V: p' H* b$ A6 n
        Dim newMenuItem3 As AutoCAD.AcadPopupMenuItem
( _. `: G4 l$ T5 k) \; c        Dim newMenuItem4 As AutoCAD.AcadPopupMenuItem
, r) q/ o8 B0 H        Dim newMenuItem5 As AutoCAD.AcadPopupMenuItem: X1 ^9 Z) M* A, V
        Dim openMacro1 As String* d) `- s: T* ?$ u
        Dim openMacro2 As String: n) L6 P, y  B; i1 B! @( p& N
        Dim openMacro3 As String' k& L9 C# ]* U6 U  e
        Dim openMacro4 As String* d( q! M- i: g" z  A' E
        Dim openMacro5 As String8 q- J& {- y2 U
        '定义菜单宏
0 O% ^8 O) l) F: M# m! X3 X/ P9 T        openMacro1 = Chr(3) & Chr(3) & "shell" & Chr(13) & "齿轮结构参数化三维造型.exe" & Chr(13)4 |4 ^0 j& \/ }$ c0 |/ s
        openMacro2 = Chr(3) & Chr(3) & "shell" & Chr(13) & "斜齿轮.exe" & Chr(13)
2 y4 ?6 m1 W& m) [. ^1 w! W        openMacro3 = Chr(3) & Chr(3) & "shell" & Chr(13) & "尺寸公差自动标注.exe" & Chr(13)! G/ D/ l9 I1 C2 b
        openMacro4 = Chr(3) & Chr(3) & "shell" & Chr(13) & "形位公差自动标注.exe" & Chr(13)2 q8 N& g, ]# O2 Y
        openMacro5 = Chr(3) & Chr(3) & "shell" & Chr(13) & "Access数据库管理图形.exe" & Chr(13)
: R$ |& y1 P0 V+ J1 k; p) R, B7 O, b        '创建菜单项. x" U0 \% C) H
        newMenuItem1 = NewMenu.AddMenuItem(NewMenu.Count + 1, "齿轮结构参数化三维造型(&A)", openMacro1)
+ {& h* [4 L% n        newMenuItem2 = NewMenu.AddMenuItem(NewMenu.Count + 1, "斜齿轮(&C)", openMacro1)8 `5 X& ^) |8 Y( x, t" ]
        newMenuItem3 = NewMenu.AddMenuItem(NewMenu.Count + 1, "尺寸公差自动标注(&D)", openMacro1)
! L# y' R# _" a; b7 V) I1 i" l        newMenuItem4 = NewMenu.AddMenuItem(NewMenu.Count + 1, "形位公差自动标注(&E)", openMacro1)
/ l, z; s6 {" e( @0 R! p        newMenuItem5 = NewMenu.AddMenuItem(NewMenu.Count + 1, "Access数据库管理图形(&F)", openMacro1)
( j- o3 \* H( V) ]5 f: w" O        '在菜单条上显示菜单
/ Q2 b5 Y0 ]) p& j        NewMenu.InsertInMenuBar(Acadapp.Application.MenuBar.Count + 1)
) Q# a3 V- j- C5 c$ K9 c) Z        Acadapp = Nothing% I! U8 x: m1 E: _  \
    End Sub% U5 k- b0 G3 C
End Module
/ K: E% }0 F2 T( b8 X4 F, W. O6 D9 H) R
发表于 2011-5-25 13:15:43 | 显示全部楼层
拿来试试,表中格式符号可能有点麻烦。
发表于 2011-11-6 17:32:25 | 显示全部楼层
能介绍一下这是什么东西吗?该如何操作呢?
发表于 2011-11-27 16:45:44 | 显示全部楼层
看这个头都大了! m( p  W0 \3 u2 b1 Y; i
能解释一下干嘛的吗
GMT+8, 2025-10-18 16:10 , Processed in 0.065351 second(s), 15 queries , Gzip On.
