工程图下导出PDF+DWF,部分宏
9 J7 z: r/ D( Y6 DDim swApp As SldWorks.SldWorks
( `$ V4 p4 O9 `! m: X, ], ^0 QDim swModel As SldWorks.ModelDoc22 t/ ~, ^6 N7 g0 A" H- o2 S# x
+ A/ \6 G3 L6 t$ |$ pSub main()- c1 f0 N6 x9 }) U
: L$ e. D8 z/ ^' j2 d2 b
Set swApp = Application.SldWorks8 i& i4 \8 e! a+ A
Set swModel = swApp.ActiveDoc7 T+ w# E9 n: m, H6 C9 p; W$ }
' k: n5 K/ `$ }4 D# I
' Check to see if a drawing is loaded.3 }1 @& k, e; B& w$ F2 C ~2 ~- \. p
If (swModel Is Nothing) Or (swModel.GetType <> swDocDRAWING) Then; O/ s% M; U, C" N* g
' {3 D; w5 G9 s K j) S
swApp.SendMsgToUser ("To be used for drawings only, Open a drawing first and then TRY!")" k& K3 w% ^, N9 G% H u
2 j. X# G* [. E! X- V1 e
' If no model currently loaded, then exit" L# \# h ?. e* |$ N
Exit Sub9 e. ~; A% g- T4 t: R5 C
' U7 D5 ]9 @( _& L' H6 o( D0 Q" O rEnd If1 T3 G( _, ?' Z9 [/ E8 {* u
8 X+ |( U! H/ G% fSet swDraw = swModel d" D8 O/ b" o& a6 x @
Filepath = Left(swDraw.GetPathName, InStrRev(swDraw.GetPathName, "\"))
2 c' @: s( b W9 d' d( `/ z
& u; Z& z+ V' J0 i! cIf Dir(Filepath & "导出图纸", vbDirectory) = "" Then ' Change Sub folder Name here) t- Y; f4 A. }6 U3 ~- }" T
MkDir Filepath + "导出图纸" ' Change Sub folder Name here" z: S9 B, _3 L' L
End If
1 i' B& E3 `# Q% r. i1 a( NFilepath = Filepath + "导出图纸\" ' Change Sub folder Name here( [1 k$ L6 I7 i+ ?9 Y
2 a* G9 p L1 j# F( \. [
Set swCustPrpMgr = swModel.Extension.CustomPropertyManager("")
% j) J9 x0 }" L4 N2 N! i5 l swCustPrpMgr.Get3 "", False, "", Value 'Change here the var revision "Rev"
% z M3 U6 w9 c8 Y0 j5 O8 I+ O6 b1 [- ~) ~5 [2 y
FileName = Mid(swDraw.GetPathName, InStrRev(swDraw.GetPathName, "\") + 1)1 p1 M# H/ X, m: ?" g& T* S
FileName = Left(FileName, Len(FileName) - 7) & "" & Value & ".pdf"
% ?7 T. N7 Z% f2 zswDraw.SaveAs3 Filepath & FileName & "", 0, 09 w1 L& y4 t& `1 \! w+ U5 K9 \/ L
# K& O5 \( U" I7 B1 O/ N( ]
'-------------------------------------------------- SAVE DXF
) j: {& b1 y2 M0 i, {. i1 [3 v' W
- x {6 ^4 c( W. dSet swDraw = swModel5 t- T, r7 |( r6 t6 T, g
Filepath = Left(swDraw.GetPathName, InStrRev(swDraw.GetPathName, "\"))7 {; l" z9 A8 B- a* |# a
' M4 B% T) V1 _4 b, P1 W: e1 DMkDir Filepath + "导出图纸" ' Change Sub folder Name here
) `6 ?6 n; [ m4 a AEnd If& B5 Y3 \2 }. y9 t
Filepath = Filepath + "导出图纸\" ' Change Sub folder Name here. u* g4 R6 _, k3 S
: p2 Y1 Q; n* p1 ?+ b: c
7 T9 u- }$ N% B3 ]5 L$ o* W; s4 x swCustPrpMgr.Get3 "", False, "", Value 'Change here the var revision "Rev"
: K* w v; z% s$ s" E# {8 k
) C" C$ P) x5 X9 P) AFileName = Mid(swDraw.GetPathName, InStrRev(swDraw.GetPathName, "\") + 1)8 n0 B2 C: j! k; \
FileName = Left(FileName, Len(FileName) - 7) & "" & Value & ".DXF"* b, t, Y( m. w2 Z+ p" p" `, r
4 |) F$ h: u4 v' |7 y# h$ U$ DswDraw.SaveAs3 Filepath & FileName & "", 0, 0
4 b; \9 K! E& P8 u0 a8 e3 R5 z5 A1 W, ?2 P; p7 h3 n+ y7 q8 ^' u1 \
swDraw.Save3 y1 |, ]2 ^0 b- P: m/ R. C, f
3 ~5 i1 R( t" R5 P' w'swApp.ExitApp '关闭SW软件
9 h% D! R$ Z9 F( _7 N* C! KEnd Sub. M ~2 t' g! T" A
# k4 g* k+ a+ a" i1 h: g3 O! _. r2 q2 ^- C
