查看: 1917|回复: 2
公差标注移层设色成功,为何还报错?
发表于 2022-8-11 13:36:34 | 显示全部楼层 |阅读模式
            Set swgtol = swgtol.GetNext
1 A" T  ]. z0 V# `8 T9 g+ s! [2 r9 h% c/ s7 R$ @9 N
如下所示代码,能执行成功,但老是上面这句报错,请大侠指点,谢谢
7 w" W6 T0 \) r8 a6 T. s/ e
1 F2 p3 `8 }$ |; d# U. j6 ?6 R4 M+ v; M) }0 H( u$ q) ~
' {( T# {/ K5 H3 a6 t, @# K& f! u5 g4 Y8 u% f* S* W
Const toLayer4 As String = "符号"
$ t; o8 i/ q9 }+ l9 B/ V' q- B. J  ?
. l+ Y5 r7 ?/ K* r/ N
Sub main()5 k  p( R3 X& \! ?) V9 t
  Dim swApp As SldWorks.SldWorks
1 l- w" r7 a3 F! H  Dim swModel As SldWorks.ModelDoc2" a' _: ~9 [2 J" V2 O# p# G9 D4 I
  Dim LyrMgr As LayerMgr
6 c* b+ R& o8 ~% P" o  Dim Layer As Variant1 O. D: t# O9 w+ N" c4 F
  Dim swDraw As SldWorks.DrawingDoc5 ]; E! K1 g5 U- z9 B% v! b7 y
  Dim swView As SldWorks.View/ z% Y. z; P# Q* |. P0 E
  Dim swAnn As SldWorks.Annotation0 i5 c- C0 N' Q0 |& O9 x
; n, S# ^+ q8 a4 m Dim swgtol As SldWorks.gtol9 o( {* o% a% o  W, F) y, U
7 ^& J7 @" J. ?: W+ k0 M2 q& |) @8 _* [$ v9 N# P$ C
  ( k2 G. s  p& k/ Z
6 y6 M! ]6 |# G& c) j3 J
  Dim numshts As Long
- |/ R% n3 F& J+ R$ N/ }) a" b8 x  Dim i As Long* g) w3 h0 L, J! t6 b' g0 `, K
  Dim SheetName() As String
: B  S! l! Q* Z% n  p  Set swApp = CreateObject("sldworks.Application")* O, K( n" T9 c; a- n( Y. w" r9 J1 n
  Set swModel = swApp.ActiveDoc  _3 \* q: S- r, C5 X
  Set LyrMgr = swModel.GetLayerManager
6 }. @+ `5 X/ J% E% K+ G  Set swDraw = swModel) F2 U8 j/ U+ H$ a3 ?
2 |, L% @$ d. d/ ]; \9 u/ T  LyrMgr.DeleteLayer ("符号")
9 Q9 Q, a3 o1 `; ]* Z, q  Layer = LyrMgr.AddLayer("符号", "符号", RGB(0, 0, 0), 0, 0) '指定顏色
/ \+ N1 N9 O  i% b6 O$ q( P6 D$ e" B
: [% @8 M! a, A& w
! o* g2 u  a% M6 n; }  numshts = swDraw.GetSheetCount
1 Q; r0 U( u7 i0 V% L  For i = 1 To numshts
( J2 Z3 j/ s! |4 e+ l    swDraw.SheetPrevious& ?3 `& x& |8 B: l. S. x. Q
  Next i, \+ r: H% D) F( T( Y) \. u
  For i = 1 To numshts6 _' k4 ?) J/ m- |
    Set swView = swDraw.GetFirstView
& _+ h# t& }( s% p* P" @, t# A    While Not swView Is Nothing
# L0 o( T! G& [6 t" V1 ~    ' _) F: q2 \% |! I9 ?$ z' }- e
7 E, c2 s, _8 Z% z9 N1 V( k( q; Q
        Set swgtol = swView.GetFirstgtol
) Y' L6 @+ R6 p' X8 F! K9 g        While Not swgtol Is Nothing
9 }  t1 \/ Z, T            Set swAnn = swgtol.GetAnnotation- s! Y$ B4 b% }4 i# \, O
            swAnn.Color = -1
. U0 j5 W8 u6 P3 Y            swAnn.Layer = toLayer37 O9 m8 o# L% s- u
/ c( o. V: }6 \$ `        Wend7 N# M! ~* w* J2 ?6 z. R
+ V+ M& o9 C  G4 {  [( [5 c0 V: n8 v4 \
         % T9 \( P8 \4 ^$ O) t
        Set swView = swView.GetNextView
; n6 t2 D+ F. z1 H, H( M+ t    Wend
3 R" G' q% V- Y: w( ]    swDraw.SheetNext' O2 ^; _2 z. B, ?) f, n0 y2 k
    Dim swLayerMgr As Object
+ e3 q2 x0 k: M. V' L% I    Dim swLayer As Object
6 i8 E) h: T3 I/ x7 U4 S6 C    Set swLayerMgr = swModel.GetLayerManager* O8 i" ^, P1 }  K7 e7 \, I- |8 b
    swLayerMgr.SetCurrentLayer ("")
, L+ r  A: K8 i1 D/ j  ~9 O; w  Next i( V4 X  V) R8 ^9 f# ?, O, R
  SheetName = swDraw.GetSheetNames
- p' P: y6 f* N4 j( ?  swDraw.ActivateSheet SheetName(0)3 ?  D& L2 t& j# r' V" R/ X7 K* x
End Sub& n4 G1 U$ z4 O9 m- H
4 j( O4 T0 h7 Y8 f; S* x4 E
8 H) G% N/ v# p) s  e3 @+ A
% {" y5 X/ o. ~) u. N# `3 l1 `
您需要 登录 才可以下载或查看,没有账号?注册会员
发表于 2022-8-11 13:58:03 | 显示全部楼层
不能成功解压啊。
 楼主| 发表于 2022-8-11 14:05:28 | 显示全部楼层
3 X) g+ c* W1 H0 t0 e5 |  ?3 i- k4 t$ w' s$ u
' ]* f( B  \  R注:从新下载后把后缀改成swp,或直接复制上面的代码。
* z0 a$ }, Y' k# E6 P' {
GMT+8, 2025-9-19 10:22 , Processed in 0.058433 second(s), 16 queries , Gzip On.
