/ }, c" X/ l/ ] o! s; I
5 ?. t8 u7 ?1 S1 X, L由于模型需要测量总的重量,可通过宏来一键添加solidworks自带材料中304密度不是7。9需要自定义材料& K' k3 f; R. [8 I/ A
* q$ p* ^' y0 Z) O7 x7 f也可以通过批量打开(dim)来实现1 m2 P r$ _( \% I8 n6 C% W% u
5 L- x% R V8 [; L* [; y
5 h( N4 Z3 V5 ~" D
宏代码如下
* s& n' X8 H; g6 i9 }3 A* g3 I% M( k- E. h6 ^) S' e; r
Dim swApp As Object
8 I) j ?1 k+ D1 p9 CDim Part As Object
% Y! l- C% r! X, I3 Y6 gDim boolstatus As Boolean7 o! A. l# E/ O+ N6 [
Dim longstatus As Long, longwarnings As Long R; N3 u0 z9 G0 s) ]; X+ J
Sub 自适应材料()
1 }. u, G8 D# g* t& X) ~ Dim N( Z0 B9 W4 g- I( K9 W ?
Dim a, b
1 x s. l. [2 B7 ] Dim name, NAME1
4 N% E8 }, ~2 Q3 o8 w0 @ J Set swApp = Application.SldWorks# U+ Q% [) Q! t* M% G `
Set Part = swApp.ActiveDoc; u) C0 F7 Z7 b$ a6 g1 h" L1 x7 y
Set selngr = Part.SelectionManager
6 q. F& y" C$ I1 v$ l: ~* U swApp.ActiveDoc.ActiveView.FrameState = 13 l4 ^" p0 H+ P& d# [+ S
N = swApp.ActiveDoc.GetTitle() '取得文件名( O _; U2 g* C
Set swModel = swApp.ActiveDoc* `* r2 i' t# K: Z2 s
Set swConfig = swModel.GetActiveConfiguration
- ~+ C9 R! ~" h" z$ H CFGNAME = swConfig.name() '当前配置名称
: u0 h! M% N k, k4 u# E1 g) Z5 n' B NAME1 = CFGNAME
: R' F1 P1 H- A, s) m1 k* d+ v For i = 1 To Len(N)* E4 T" B e& k$ L5 R8 R4 e
a = Mid(N, i, 1)) ^0 I' E8 t# t; X# r
b = Mid(N, i, 2)6 U! X4 x" ^! R; K9 p
If a = "瓷" Then
0 \0 y: W# E5 P: V" w name = "A95瓷管"0 w8 g. a" k0 i3 d6 }1 A7 F4 Q
Exit For
$ _( v+ _$ M) B1 q0 u ElseIf a = "铜" Then- m9 }8 j5 J. d
name = "铜"
. [) ^ e) g9 R. f1 b5 |1 ~1 Q Exit For
+ K7 H- o/ u9 y& c) s! G" j ElseIf b = "环氧" Then
* ~9 X* V, }5 L/ v# m7 R name = "环氧板": }1 u8 u8 Q% h& @- {. m
Exit For
; R4 y3 ?, y7 E; F ElseIf b = "云母" Then
3 R3 `9 q% w; v& c4 I, W t name = "云母"+ W3 f- L: {+ C& }2 k' w
Exit For% O' C; k1 ]2 j$ b
Else
( L: R2 P; R2 w5 x, P5 W- g name = "SUS 304"
% _3 C8 f+ h1 c0 | End If L0 Y; ? |; c" `
Next: s1 f9 r8 z8 s# [/ n& d
Set Part = swApp.ActiveDoc% N; b4 _( s6 j- F. U: v$ \1 S# j
boolstatus = Part.Extension.SelectByID2("未知", "BROWSERITEM", 0, 0, 0, False, 0, Nothing, 0)
7 J* f% L3 m! W6 U boolstatus = Part.Extension.SelectByID2("未知", "BROWSERITEM", 0, 0, 0, False, 0, Nothing, 0)
l6 d- Z* U6 v Part.SetMaterialPropertyName2 N, "C:/Program Files/SolidWorks Corp/SOLIDWORKS (2)/lang/chinese-simplified/sldmaterials/materials.sldmat", name
+ m% \# l+ D: T. {' k Part.SetMaterialPropertyName2 NAME1, "C:/Program Files/SolidWorks Corp/SOLIDWORKS (2)/lang/chinese-simplified/sldmaterials/materials.sldmat", name
4 z( J: t3 X. C Part.Save '保存" c4 j }: q, d. q J6 j; W
End Sub
1 Z/ E" u p6 M! Z& u. v% x由于无法上传宏文件,需要的可以留个邮件
5 Q$ l' k, d& s3 D5 S! `5 y% }$ M
3 p; X1 J1 B$ M3 o" O) o
- B' H* V* ]8 j6 m0 q" c& t( X2 `
您需要 登录 才可以下载或查看,没有账号?注册会员
