查看: 6491|回复: 11
汉英化工机械词典
发表于 2007-12-25 15:10:27 | 显示全部楼层 |阅读模式
专业词汇词典论坛上有不少,不过没见过化工机械词汇的。" |" V0 |- |  @4 q6 x1 ~
+ u) y6 f% D( H/ e* u发个与大家分享。
2 h, y% y3 o# H2 i( R0 d8 y. W6 n2 F0 F7 {/ H) d/ d
汉英化工机械词典pdf,653页,7压缩包。# k: f! _# d. {( X
3 ?7 H  b6 D. i3 s7 \# i+ [1 b# y' m截图:
本帖子中包含更多资源
您需要 登录 才可以下载或查看,没有账号?注册会员
发表于 2008-1-3 23:07:22 | 显示全部楼层
Thanks very much.
发表于 2008-12-9 19:58:10 | 显示全部楼层
谢谢啊!
很谢谢你的!!
发表于 2008-12-13 11:28:32 | 显示全部楼层
Thanks very much.80.WATH
发表于 2009-10-9 11:16:45 | 显示全部楼层
下不下来。
发表于 2009-10-15 23:20:36 | 显示全部楼层
wedding dress chooseIf you are planning all of the details wedding dresses,glove,wedding dress,of your wedding down to the design on the napkins at the reception you really have your work cut out for you.wedding dresses, This can be a wedding dresses, very overwhelming task. Yet the rewards are also great. Having a wedding day exactly like you gloves, had always dreamed of is gloves, a huge reward. However knowing that  cheap wedding dresses,you planned all Wedding Gowns, of the details yourself makes glove, it that much sweeter. One of the things you will Prom Dresses, want to consider is Prom Dresses, wedding jewelry for bridesmaids.wedding dresses, This is not a have to and many times you can skip this.gloves, However, if you are wedding dresses, serious about choosing all of 2009 Wedding Gowns, the details and having everything come out just Prom Dresses, perfect then you glove, will want to wedding dresses, choose the jewelry cheap wedding dresses, for your bridesmaids. One of the biggest wedding dress, side benefits of choosing your cheap wedding dresses, wedding jewelry for the gloves, bridesmaids is it can also serve the second function of being a bridesmaid gift after wedding dress, the wedding.wedding dress, This article glove, will help guide your through making some gloves, of the important wedding dresses, decisions when choosing wedding dresses, wedding jewelry Wedding Gowns, for bridesmaids.
发表于 2009-11-12 22:34:05 | 显示全部楼层
楼主能不能帮帮忙,共享资料不要那么多限制嘛
发表于 2009-12-13 15:19:11 | 显示全部楼层
我下不了啊 9 x) K& @9 U: `1 j: I- e
权限干嘛设那么高啊
发表于 2009-12-15 14:25:48 | 显示全部楼层
就是、权限那么高怎么下载呀
发表于 2010-2-23 21:04:41 | 显示全部楼层
虽然下不了,还得谢谢楼主
GMT+8, 2025-9-14 04:33 , Processed in 0.065840 second(s), 16 queries , Gzip On.
