yuzhiboyou2014 发表于 2015-6-2 11:32:22
有没有外籍机加工专家愿意到东莞工作?
不知道各位大大身边是否有外籍机加工专家愿意到东莞工作呢,年龄可以放宽到60岁,年薪优厚。
zyk566515 发表于 2015-6-2 11:53:48
外籍? 外地户籍,还是外国户籍??
dongst 发表于 2015-6-2 12:02:45
外籍就是外籍,外地就是外地。
看重外籍,大概是希望有张“国际化”的脸面吧,欧美的就困难了,来国内教个英语都要十几k月薪,做操作工,可能要翻倍才愿意来吧。
极速尖兵 发表于 2015-6-2 12:21:26
找阿三吧,工资没有欧美高。
shootbomb1 发表于 2015-6-2 12:44:07
LZ说具体一点吧,比如:
针对什么类型的产品
工作类型是维护改善顾问型的,还是零基础出方案的,还是带团队
外籍人员资质和能力要求
合同期限
年薪范围
说下我了解的供参考
我认识得的超过60岁了,经验和能力都没问题,但都是基于不同产品,没有所有产品都精通的全才。
以某一类产品为前提,从毛坯到成品,包括刀夹量辅,从工艺到检测,至少做顾问没有问题。
年薪和工作类型,工作量,压力等等有关
yuzhiboyou2014 发表于 2015-6-2 14:58:21
谢谢上面,行家扎堆的地方就是不一样,外籍是客户要求(个人认为如果英文精通熟悉外企文化且有15年以上机加工经验那么华人亦可),年薪在70-80万RMB吧视经验而定,至于产品吗可以以TTI的产品为参考,另外要强调一点的是这不是一个管理岗,不需要带团队,像楼上所说的更像一个顾问,稍后我把工作描述贴出来
yuzhiboyou2014 发表于 2015-6-2 15:00:24
以下是工作描述,暂时只有英文版的,
Position: Expatriate Machining Expert
Reports to: Operations Director
Working Location: Dongguan City, Guangdong Province, CHN
_____________________________________________________________________Position Summary
Expert machining principle specialist in CNC turning, grinding, hobbling and milling process, work closely with Production/MET/PRC project engineering (NPD) teams to validate designs, and ensure the optimal manufacturability, consistency and cost of both new & existing product categories.
Key Responsibilities
•       Participate in Kaizen and project engineering as necessary.
•       Identify, prepare and implement improvement opportunities that support optimum production and consistency/ quality levels.
•       Identify & drive cost improvement opportunities.
•       Work with NPD team to validate designs, performance goals and specification.
•       Identify and review jigs/fixtures which are used in machining process.
•       Select tools, cutting parameters and chose the best procedure of mass production.
•       Follow up new machining processes and technologies and introduce to team.
•       Work closely with quality team to analyze and solve quality problems.
•       Optimize and improve current process to achieve best efficiency and cost.
_____________________________________________________________________Person Specifications
•        College, degree or above education, machining manufacturing focused.
•        Over 15 years work experiences with metal machining.
•        Proficiency in UG or relevant 3D software.
•        Profound knowledge of different equipment structures and maintenance.
•        Be able to tackle quality and technical issues effectively.
•        Profound understanding of mechanical components and GD&T (geometry tolerance and dimension tolerance) requirement.
•        Experience in measuring method and knowledge of material and heat-treatment.
•        Experience in setting up and writing CNC code and CAM software integration.
•        Have rich experience in many types of manufacture process included turning, milling, grinding, hobbing and CNC(4, 5axis), EDM, W/C etc.
•        Be able to work effectively and efficiently.
•        Reading English is required.
•        Hydraulic product experience is a plus.
Leadership Competencies Required
•       Be independent to take immediate, correct actions without being pushed.
•       Excellent communicator.
•       Create and maintain an effective communication atmosphere in and out of the dept. with a timely, high quality manner.
Functional Competencies required:
        Support and establish partnership at different levels in and out of the working team or organization.
        Good understanding of being unique and be able to adjust methods effectively to hit the goals.
        Machining knowledge
阳光小院暖茶 发表于 2015-6-2 16:13:08
高薪果然得要两把刷子:lol光这英文就比高考的阅读理解还难啊
夜战茵特莱特 发表于 2015-6-3 11:04:52
干嘛 要高薪找外籍的呢   当顾问?那还要请个翻译的了
shootbomb1 发表于 2015-6-3 11:29:14
看工作描述挺实在的,这个要求,确实找外籍的比较现实
查看完整版本: 有没有外籍机加工专家愿意到东莞工作?
