查看: 4827|回复: 10
机械密封涉及国家标准(整理)
发表于 2013-1-22 15:07:49 | 显示全部楼层 |阅读模式
1
GB 4806.1-1994
Hygienic standard for foodstuff rubber products
食品用橡胶制品卫生标准
GB 5083-1999
General rules for designing the production  facilities in accordance with safety and health requirements
生产设备安全卫生设计总则
3
GB 12073-89
Security and sanitary standard for dairy equipment
乳品设备安全卫生
4
GB 16798-1997
Requirements of safety and sanitation for food machinery
食品机械安全卫生国家标准
5
GB/T 14211-2010
Test method of mechanical seals
机械密封试验方法
6
JB/T 2934-2006
Carbon material and carbon products for mechanical engineering
机械用炭材料及制品
7
JB/T 4127.1-1999
Specification for mechanical seals
机械密封技术条件
8
JB/T 4127.2-1999
Classification method for mechanical seal
机械密封分类方法
9
JB/T 6629-1993
circulating system of Protecting mechanical seals
机械密封循环保护系统
10
JB/T 7369-1994
Inspection method of mechanical sealing surface flatness
机械密封端面平面度检验方法
11
JB/T 7401-1994
Optical flat
平面平晶
12
JB/T 7757.1-1995
Coil Springs used in mechanical seals
机械密封用圆柱螺旋弹簧
13
JB/T 7757.2-2006
The rubber O-Ring for mechanical seal
机械密封用O型橡胶圈
14
JB/T 8872-2002
Specification for carbon-graphite sealing ring for mechanical seal
机械密封用碳石墨
15
JB/T 10706-2007
Rubber O-ring coated fluoride plastic for mechanical seal
机械密封用氟塑料全包覆橡胶O形圈
16
JB/T6619.1-1999
Specification for light mechanical seals
轻型机械密封技术条件
17
JJG 28-2000
Optical flat
平晶检定规程
18
SB/T 222-2007
General speciafication for food machinery-basic technical requirements
食品机械通用技术条件 基本技术要求
19
SB/T 223-2007
General speciafication for food machinery-technical requirements for machining
食品机械通用技术条件 机械加工技术要求
20
SB/T 224-2007
General speciafication for food machinery-technical requirements for assembling
食品机械通用技术条件 装配技术要求
21
SB/T 225-2007
General speciafication for food machinery-technical requirements for casting
食品机械通用技术条件 铸件技术要求
22
SB/T 226-2007
General speciafication for food machinery-technical requirements for welded and riveted components
食品机械通用技术条件 焊接、铆接件技术要求
23
SB/T 227-2007
General speciafication for food machinery-technical requirements for electrical installations
食品机械通用技术条件 电气装置技术要求
24
SB/T 228-2007
General speciafication for food machinery-technical requirements for paintings
食品机械通用技术条件 表面涂漆
25
SB/T 229-2007
General speciafication for food machinery-technical requirements for product packing
食品机械通用技术条件 产品包装技术要求
26
SB/T 230-2007
General speciafication for food machinery-Rules for product quality inspection
食品机械通用技术条件 产品检验规则
27
SB-T 231-2007
General speciafication for food machinery-Rules for product labeling, transporting and storing
食品机械通用技术条件 产品的标志、运输
% H& o( g) b: I& T6 U0 }6 b: s4 R与贮存
# F2 p7 I, w0 c
2 C( R! B7 C% q6 |- W. F1 F
7 Q' l4 B6 K+ v7 U+ P. v+ y前段时间整理的一个表格,主要是涉及一些食品卫生行业的标准.. f. B1 U3 Y( t) a: M0 m! h0 i. n; y
有时候看到国内食品机械设计上有很多弊端,希望能让行业内的人了解一下.
% Y$ v* S* i+ O7 f& `7 M
4 ?: x7 v- j9 K  L另外, 一些国外的FDA,3A,BS也有不错的指导意义。
" x  e! X$ D, ~
% z) Q0 y" P* Q3 ?! A3 P# W$ h7 g2 U$ E( w* I. l6 H. Q! K
参与人数 2威望 +20 收起 理由
憨老马 + 10 热心助人,专业精湛!
老鹰 + 10
 楼主| 发表于 2013-1-22 15:15:04 | 显示全部楼层
1 m+ n. W2 A/ C% H# b
. C8 _* S& L9 g" h
9 ]# g1 w0 o( R- e# c# @$ u' X- g9 g# F9 R5 `: A
0 I# q! g% v2 N7 m6 ]6 N! S  h# {& B, k) m
) u/ A1 x% J. t, M. V  \- y- W8 b6 h* O
: M/ d. p! o- d
8 R2 J, i* P9 G" V
1 L4 a4 \- V3 |0 F
! K) ~* z! t1 h& k' B# s8 C+ x
本帖子中包含更多资源
您需要 登录 才可以下载或查看,没有账号?注册会员
 楼主| 发表于 2013-1-22 15:15:41 | 显示全部楼层
To be continued
发表于 2013-1-22 15:31:44 | 显示全部楼层
不错的资料,谢谢楼主分享
发表于 2013-1-22 16:06:44 | 显示全部楼层
楼主从事食品行业么?
 楼主| 发表于 2013-1-22 16:09:55 | 显示全部楼层
hc2003 发表于 2013-1-22 16:06 2 o) C# d+ S; C' i* Q1 ]
楼主从事食品行业么?
1 O4 W$ ]  B& g
不是,我是做机械密封行业的,只是有时候会涉及到食品行业的泵或者搅拌器。
发表于 2013-1-22 16:13:04 | 显示全部楼层
机械密封行业听好的吧,水泵上用的多
 楼主| 发表于 2013-1-22 16:15:50 | 显示全部楼层
我觉得行业谈不上好坏,很小的行业。。。
发表于 2023-11-7 13:50:45 | 显示全部楼层
感谢楼主
7 R7 O" p6 e, O8 I' u
发表于 2023-11-13 20:37:13 | 显示全部楼层
机械密封行业听好的吧,水泵上用的多
GMT+8, 2025-6-16 12:15 , Processed in 0.084815 second(s), 19 queries , Gzip On.
