求结构
本帖最后由 诺克糖果 于 2025-5-6 14:58 编辑图中是一个断路器检测台的触头,该台子有三个并列的触头,现在是要设计一个结构能套在这个触头上,从结构上要引出一根导线来去给小的微断通电,每个触头都要引出线来,而且必须要套紧,且三个触头之间的间距在20mm左右,求助社区大佬有没有新思路提供一下,绞尽脑汁也没想出来合适的。
模型可能看不懂,给大家看一下实物图 用铜皮条贴着然后用热缩管固定。 恕我直言,没大听懂,我都没咋明白图里的是啥东西.... TakiLee 发表于 2025-5-6 14:45
data:image/png;base64,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这种东西,给断路器通电测特性的,现在要从上面引出导线来给小型断路器通电,电流最大要1200A
没接触过,有点懵,
上面老哥说的热缩管,还有在件中间开孔、在侧面开槽配压片,不知道行不行
TakiLee 发表于 2025-5-6 15:07
没接触过,有点懵,
这个触头还不让动,热缩管怕是不行,电流大了发热耐不住吧 你的意思是要做个东西 带引线然后插在图片中的触头上? 套的东西要求退出去吗?如果只是固定在一起,不动,热缩管啥的都可以,如要要求拔插的话,你实物中那个平面铝板,扔个磁铁,你做个罩子,里面也扔个磁铁,磁铁吸住就行,跟触头接触部分,哪个铜片折个V字型,磁铁吸住瞬间 铜片跟触头接触就行 诺克糖果 发表于 2025-5-6 15:10
不知道空间够不够,给它做个套,套个新触头上去,固定方式用紧定螺钉那种挤压式的?
xue428032 发表于 2025-5-6 15:10
你的意思是要做个东西 带引线然后插在图片中的触头上? 套的东西要求退出去吗?如果只是固定在一起,不动 ...
老哥,要可拔插的,平面是不锈钢,您说的磁铁没太理解啊
