查看: 2341|回复: 1
几种停机的危机程度,应该怎么理解?
发表于 2009-5-22 10:57:37 | 显示全部楼层 |阅读模式
Severity is the extent in which a components impacts the channel business plan4 B  D0 E$ z9 {( P4 b1 E, L
' {) @6 ]6 O8 {
6 x% ?  Y& |# ^1 X3 K  R. V# I( qCritical is an intolerable failure that results in a direct impact on the channel business plan9 x2 h  W, w. M4 Y
' f) D6 _6 {! H' ~# |
( a3 n3 y. G+ @+ E5 KNon-critical is a tolerable failure that results in a indirect impact on the channel business plan
: ^: v- c8 \9 Y  O! h' E6 ^& A
! s8 e' B3 j# d! x; R! r7 K4 C' \# `/ H# @, u; h8 s8 e. B
Tolerable means that it is an acceptable failure but requires further analysis to define maintainability3 K* G5 A8 b6 V4 R$ H
( y: y1 p& x: p6 N8 u3 ~  H) y3 j0 ]+ j7 \
Intolerable means that it is not an acceptable failure and requires analysis to define failure prevention/prediction# R/ C0 J( w, c, c' B0 k
( W# G+ g" H7 d3 u, V
发表于 2009-8-27 22:53:43 | 显示全部楼层
是‘卡农’还是‘撒卡’?我是‘塞牙’!啊点哪的‘僧抖四’
GMT+8, 2025-8-7 16:19 , Processed in 0.056799 second(s), 14 queries , Gzip On.
