qwer1213 发表于 2018-8-28 10:23:25
一个手动俯仰装置 精度4“ 最大负载15kg 新人求教
一个手动俯仰装置精度4“   最大负载15kg俯仰角度±45°有粗调和精调   粗调360°   精调10°左右    精调精度能到4″      用什么作为精调驱动好
暂时想到用测微头推动   可是负载15kg怕推不动   而且精调要能自锁的
data:image/png;base64,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各位大佬求教了    谢谢
0048 发表于 2018-8-28 11:28:20
坐等高人解答,手动,是打算用齿轮?蜗轮蜗杆? 自锁的话用蜗轮蜗杆挺好,但间隙怎么控制呢。。
建高五金 发表于 2018-8-28 12:55:48
表的时、分、秒跟度、分、秒原理一样。
threetigher 发表于 2018-8-28 13:57:26
没图没真相
qwer1213 发表于 2018-8-28 16:42:37
这个就是我目前想到的    求大佬帮忙
没图没真相
谢谢大佬了
谢谢大佬了
参考雷达。
谢谢大佬了
下面那个圆盘,是还要调节偏摆角么?
下面那个圆盘,是还要调节偏摆角么?
是的   雷达是电动的吧
ozc1352 发表于 2018-8-28 17:36:11
学习一下大佬的技术
查看完整版本: 一个手动俯仰装置 精度4“ 最大负载15kg 新人求教
