钻模的钻孔精度计算与推力夹紧图例
一.钻模的钻孔精度计算https://5b0988e595225.cdn.sohucs.com/images/20180629/042d54f46b3f4477b6baabf143e33066.jpeg图1 计算公式公式符号注解见下图:https://5b0988e595225.cdn.sohucs.com/images/20180629/34ed9376321f4eb78d6142b004d494f8.jpeg图2二.推力夹紧https://5b0988e595225.cdn.sohucs.com/images/20180629/a2b35092be5246fc9a4590bfd5908b01.jpeg图3A的凸轮C推动推杆B,凸轮D使它退回。https://5b0988e595225.cdn.sohucs.com/images/20180629/c826c27d751643a280f4bdd19529dd4f.jpeg图4C中的销B经凸轮推动推杆A。凸轮的小角度锁紧推杆。https://5b0988e595225.cdn.sohucs.com/images/20180629/ab79f9deec6546c59c9b633a507fbe39.jpeg图5A和B是分开的零件,用螺栓紧固在一起,螺栓也可防止凸轮转动。注意螺栓上的二个键。https://5b0988e595225.cdn.sohucs.com/images/20180629/925c4a2dfdf84ce9a58bdce7ba041d76.jpeg图6销A在底座C上,凸轮和B上均开有槽。https://5b0988e595225.cdn.sohucs.com/images/20180629/f557058bfc184b64a0a29517238ed495.jpeg图7凸轮E传动摇臂C,C迫使B推A至工件。弹簧D退回A,F防止A转动。G处形状是让A得以充分退回。https://5b0988e595225.cdn.sohucs.com/images/20180629/daef8a735da4436b9b9a02a258b9160a.jpeg图8A和B不在同一平面上。https://5b0988e595225.cdn.sohucs.com/images/20180629/254f5a07b8bc4fecbe2659c78d11120e.jpeg图9肘杆夹紧装置的设计基本原理也用于夹钳的设计中。当B位于A和C的连线上时,顶杆具有最大的压力。把B限止在稍为偏离直线AC的地方,则可防止由于振动而松夹。注意松开起始时销子的位置。https://5b0988e595225.cdn.sohucs.com/images/20180629/f141ef83f334459ba51f880c5e421a4e.jpeg图10将此肘杆夹紧装置与已介绍过的进行比较。http://5b0988e595225.cdn.sohucs.com/images/20180629/0df11d1d36634badba25f7ba13f03833.png图11把这个肘杆夹紧装置与已介绍过的进行比较。此装置需有一个止销。注意螺丝接头的调整。https://5b0988e595225.cdn.sohucs.com/images/20180629/dc67047905034b9f9edbddb0343cb57c.jpeg图12把这个肘杆夹紧装置与已介绍过的进行比较。https://5b0988e595225.cdn.sohucs.com/images/20180629/ac2c0d05df5d4d4bb4122bc1e15db863.jpeg图13工件装上后,A穿过工件的孔面伸出并加力于B以传至支点C,在D处推紧工件。https://5b0988e595225.cdn.sohucs.com/images/20180629/558bb424c1ef4b7ea988a0528c0bde19.jpeg图14在凸轮C与锁紧销D接触之前,弹簧把顶杆A推向工件。B防止凸轮C转动并防止它在退回时超过D。B也使顶杆A退回。https://5b0988e595225.cdn.sohucs.com/images/20180629/da2a7d1af47842ce9a938045e8ca7681.jpeg图15转动手柄使E和摇臂C移动,C迫使顶杆A和G夹紧。兄弟,你专门搞夹具设计的吗。
