江苏谷乐液压 发表于 2018-3-23 09:54:25
液压伺服系统设计指南VALVE SIZING AND PERFORMANCE ESTIMATION
1.0    OVERVIEW1.1 Valve Sizing andPerformance issues1.2 SpreadsheetApplicability1.3 Conventions
      1.4   Spreadsheet
2.0    USING THESPREADSHEET
2.1 Data Entry
2.2Spreadsheet Section 1 – ‘Cylinder and Pressure Supply Details’2.3Spreadsheet Section2 – ‘Valve Details’2.4Spreadsheet Section 4 – ‘Cylinder Drive Sizing Results’2.5Spreadsheet Section 3 – ‘Load and Pipe Details’
2.6Spreadsheet Section 5 – ‘ Cylinder Drive Position Control Results’
3.0    SUMMARY OF SERVO DESIGN GOOD PRACTICE
4.0    SPREADSHEET APPLICATION EXAMPLE4.1 Application(Spreadsheet Default) Details4.2 Selecting SupplyPressure and Actuator Size4.3 Valve Sizing4.4 Mass and PipelineConsiderations4.5 Closed Loop PositionPerformance
5.0    SIZING AND PERFORMANCE ESTIMATION BYMANUAL CALCUALTION5.1 Component Sizing5.2 Rules of Thumb forPosition Control Performance
6.0    OTHER OPERATING CONFIGURATIONS6.1 Cylinder EffectiveMass Calculations6.2 Three Port Operation6.3 Pressure ControlApplications6.4 Digital ControllerCalculations
Valve sizing andperformance estimation for electrohydraulic servo systems is a necessarystep if therequired performance is to be assured. On some occasions the valve itselfprovides anatural limit to performance, either in terms of maximum flow rates andthereforeactuatorvelocities, or else in terms of the dynamic performance (as described by thevalvefrequencyresponse). In the later case the valve performance limits the control gainandsoalso the closedloop dynamic behaviour and static accuracy.
In other situations thecharacteristics of
the actuator andload being drivenprovide a limitto the closed loopperformance whichwill not be improvedeven with thefastest, highest flowing ormost accurate ofservo valves.
Separating thesethings out and
optimisingperformance but without overspecifying thevalve is not alwaysobvious, andgenerally requires a numberof calculationsto be undertaken. In thisApplication Notea spreadsheet is usedfor this purpose.A minimal amount ofdata entry isrequired from which themaximum drivecapabilities and closedloop static anddynamic performance isestimated.
junshi1010 发表于 2018-3-23 13:29:49
很深奥的赶脚!
liangquan6 发表于 2018-3-23 14:40:51
这么专业的资料,我看看!
liangquan6 发表于 2018-3-23 14:42:11
嗯,是MOOG的一个技术文档,讲 电液伺服控制 设计问题
a118376 发表于 2018-3-24 17:38:43
这么专业的资料,我看看
江苏谷乐液压 发表于 2018-8-16 21:32:32
:victory:
只有快乐 发表于 2018-8-17 10:57:51
moog的东西在伺服领域还是很牛啊,资料也很好,留下来慢慢研读。
江苏谷乐液压 发表于 2018-8-26 18:10:38
就是太贵,伺服阀G761都快一万八,伺服液压系统造价比较高,还得配伺服运动控制器,伺服油缸,磁致位移传感器。
~心诚~ 发表于 2018-9-6 09:42:59
一分价钱一分货啊,贵有他贵的道理:lol
trenxim123 发表于 2018-10-31 10:41:58
伺服还用不上,可以看看学习一下
查看完整版本: 液压伺服系统设计指南VALVE SIZING AND PERFORMANCE ESTIMATION
