王树大 发表于 2017-11-2 20:42:56
米其林轮胎工厂维修间用的美国CLAUSING 牌车床,带索尼光...
带有这是美国
回轉直徑:330.2 mm
頂尖間距:762 mm
主軸孔徑:41.28 mm
功率:2.2 kW
主軸轉速:2500 rpm
橫拖板上最大回轉直徑:171.4 mm
尺寸:65"L x 34"W x 48"H
重量:2,250 lb.
1-(used) Clausing Metosa Model C1330 13" X 30" Engine Lathe, New 2003.SPECIFICATIONS:
Swing over bed............................................. 13"
Swing over cross slide.................................. 6-3/4"
Distance between centers................................... 30"
Spindle bore............................................ 1-5/8"
Spindle nose............................................. D1-5"
Spindle taper............................................ #4 MT
Width of bed............................................... 10"
Spindle speeds (9)............................... 75 - 2500 rpm
Longitudinal feed range (44)............... 0.0018 - 0.0264 ipr
Cross feed range (48)...................... 0.0005 - 0.0076 ipr
Threading range English (44)........................ 4 - 60 tpi
Threading range Metric (44).......................... 0.5- 7 mm
Tailstock spindle travel ................................... 5"
Tailstock spindle taper.................................. #3 MT
Dimensions (approx.)........................ 65"L x 34"W x 48"H
Weight (approx.)..................................... 2,250 lb.EQUIPPED WITH:
8" 4-Jaw chuck
12" Faceplate
Lever type 5C collet closer
Steady rest
Quick change toolpost
Trav-a-dial for longitudinal carriage travel
Thread dial indicator
Full length back splash guard
Coolant pump and tank
Hardened & ground bedways
3 Horse power main motorhttp://www.agreenco.com/ClausingMetosaC1330-2174.html
xiaobing86203 发表于 2017-11-2 22:03:19
这种老古董可以拿来珍藏了
小万engineer 发表于 2017-11-3 03:19:29
这公司停产了吧
成形极限 发表于 2017-11-3 05:31:30
这个床子不错
查看完整版本: 米其林轮胎工厂维修间用的美国CLAUSING 牌车床,带索尼光...
