jingliba 发表于 2007-7-6 10:15:35
起重设备标准术语(英汉)
<P align=justify>轻小起重设备^Series lifting equipments<BR>千斤顶^jack<BR>螺旋千斤顶^Screw jack<BR>齿条千斤顶^Rack-pinion jack<BR>液压千斤顶^Hydraulic jack<BR>滑车^Pulley block<BR>起重葫芦^Hoist<BR>手拉葫芦^Chain block<BR>手扳葫芦^Lever block<BR>钢丝绳手扳葫芦^Rope lever block<BR>环链手扳葫芦^Chain lever block<BR>电动葫芦^Electric hoist<BR>气动葫芦^Pneumatic hoist<BR>绞车(卷扬机)^winch<BR>钢丝绳手扳葫芦^Drum hoist<BR>环链手扳葫芦^Friction hoist<BR>电动葫芦^Capstan<BR>气动葫芦^Underslung monorail system<BR>绞车(卷扬机)^crane<BR>桥架型<A href="http://www.gzjlcranes.com/qizhongji.htm"><FONT color=#000000>起重机</FONT></A>^Overhead type crane<BR>桥式起重机 ^Overhead travelling crane<BR>门式起重机 ( 龙门起重机 ) Portal bridge crane (gantry crane)<BR>半门式起重机 ( 半龙门起重机 )^Semi-portal bridge crane<BR>缆索型起重机^Cable type crane<BR>缆索起重机 ^Cable crane<BR>门式缆索起重机^Portal cable crane<BR>臂架型起重机^Jib type crane<BR>门座起重机 ^Portal slewing crane<BR>半门座起重机^Semi-portal slewing crane<BR>塔式起重机 ^Tower crane<BR>铁路起重机 ^Railway crane<BR>流动式起重机 ^Mobile crane<BR>浮式起重机 ^Floating crane<BR>甲板起重机^Deck crane<BR>桅杆起重机 ^Derrick crane<BR>悬臂起重机^Cantilever crane<BR>柱式悬臂<A href="http://www.gzjlcranes.com/qizhongshebei.htm"><FONT color=#000000>起重设备</FONT></A>^Pillar jib crane<BR>臂上起重机^Wall crane<BR>自行车式起重机^Walking crane<BR>吊钩起重机^Hook crane<BR>抓斗起重机^Grabbing crane<BR>电磁起重机^Magnet crane<BR>冶金起重机 ^Metallurgy crane<BR>堆垛起重机 ^Stacking crane<BR>集装箱起重机 ^Container crane<BR>安装起重机^Erection crane<BR>救援起重机^Salvage crane<BR>固定式<A href="http://www.gzjlcranes.com/qizhongji.htm"><FONT color=#000000>起重机</FONT></A>^Fixed base crane<BR>运行式起重机^Traveling crane<BR>自行式起重机^Self-propelled crane<BR>拖行式起重机^Trailer crane<BR>爬升式起重机^Climbing crane<BR>便携式起重机^Portable crane<BR>随车起重机^Lorry crane<BR>辐射式起重机^Radial crane<BR>手动起重机^Manual crane<BR>电动起重机^Electric crane<BR>液压起重机^Hydraulic crane<BR>内燃起重机^Diesel crane<BR>蒸汽起重机^Steam crane<BR>回转起重机^Slewing crane<BR>全回转起重机^Full-circle slewing crane<BR>非全回转起重机^Limited slewing crane<BR>非回转起重机^Non-slewing crane<BR>支承起重机^Supported crane<BR>悬挂起重机^Underslung crane<BR>车间起重机^Workshop crane<BR>机器房起重机^Machine house crane<BR>仓库起重机^Warehouse crane<BR>贮料场起重机^Storage yard crane<BR>建筑起重机^Building crane<BR>工程起重机^Construction crane<BR>港口起重机 ^Port crane<BR>船厂起重机^Shipyard crane<BR>船台起重机^Shipway crane<BR>船坞起重机^Dock crane<BR>舾装<A href="http://www.gzjlcranes.com/qizhongji.htm"><FONT color=#000000>起重机</FONT></A>^Crane for finishing shipguilding<BR>坝顶起重机^Dam crane<BR>船上起重机^Shipboard crane<BR>升降机^Lift elevator<BR>带回转臂架的桥式起重机^Overhead crane with slewing jib<BR>带回转小车的桥式起重设备^Overhead crane with slewing crab<BR>单主梁桥式起重机^Single girder overhead crane<BR>双梁桥式起重机^Double girder overhead crane<BR>同轨双小车桥式起重机^Overhead crane with double trolley on the same rails<BR>异轨双小车桥式起重机^Overhead crane with double trolley on the diferent rails<BR>挂梁桥式起重机^Overhead crane with carrier-beam<BR>电动葫芦桥式起重机^Overhead crane with clectric hoist<BR>带导向架的桥式起重机^Overhead crane with guided beam<BR>柔性吊挂桥式起重机^Overhead crane with loose suspend<BR>梁式起重机^Overhead crane with simple girder<BR>吊钩桥式起重机^Overhead crane with hook<BR>抓斗桥式起重机^Overhead crane with grab<BR>电磁桥式起重机^Overhead crane with magnet<BR>二用桥式起重机^purpose overhead crane<BR>三用桥式起重机^purpose overhead crane<BR>通用桥式起重机^General purpose overhead crane<BR>专用桥式起重机^Special overhead crane<BR>冶金桥式起重机^Overhead crane for metallurgic piants<BR>防爆桥式起重机^Overhead explosion-proof crane<BR>绝缘桥式起重机^Overhead isolation crane<BR>桥式堆垛起重机手动桥式起重机^Manual overhead crane<BR>电动桥式起重机^Electric overhead crane<BR>液压桥式起重机^Hydraulic overhead crane<BR>司机室操纵桥式起重机^Cab-operated overhead crane<BR>地面操纵桥式起重机^Floor-controlled overhead crane<BR>远距离操纵桥式起重机^Remote-controlled overhead crane<BR>跨度^S<BR>起重机高度^H<BR>起重机宽度^B Crane width<BR>小车轨距^K<BR>大车(<A href="http://www.gzjlcranes.com/qizhongshebei.htm"><FONT color=#000000>起重设备</FONT></A>)基距^W<BR>小车基距^W c<BR>缓冲器高度^ Buffer height<BR>主梁底面位置^ Position of bottom plan of main girder<BR>司机室底面位置^ Position of bottom plan of cab<BR>主钩上极限位置^ Main hook approach to cane rail top<BR>副钩上极限位置^ Auxiliary hook approach to cane rail top<BR>主钩左极限位置^ Main hook approach to cane rail top left side<BR>主钩右极限位置^ Main hook approach to center of crane rail right side<BR>副钩左极限位置^ Auxiliary hook approach to center of crane rail left side<BR>副钩右极限位置^ Auxiliary hook approach to center of crane rail right side<BR>司机室水平位置^ Distance between cab and rail<BR>司机室底长^ Bottom length of cab<BR>起重机轨道中心至<A href="http://www.gzjlcranes.com/qizhongji.htm"><FONT color=#000000>起重机</FONT></A>外缘距离^ Dimension from rail center to crane edge<BR>主梁上拱度^camber<BR></P>
查看完整版本: 起重设备标准术语(英汉)
