SolidWorks 二次开发 求助
请问有没有哪位大哥大姐对用c++对SolidWorks进行二次开发比较熟悉的,比如下面这个轮毂怎么用C++程序画出来这是轮毂源文件
各位大哥大姐如有其他三维建模程序的,能不能传给小弟我学习学习,感激不尽了!小弟这边也有些机械方面的资料可以和大家共享。
下面是小弟编的一个程序,新建文件——创建圆柱。
/* NOTE: You will need to add the -GX flag to your Project Options in Project->Settings->C/C++*/
// swobj.cpp : Implementation of Cswobj
#include "stdafx.h"
#include "111.h"
#include "swobj.h"
// Cswobj
void Cswobj::AddUserInterface()
AddToolbar();
AddMenus();
void Cswobj::RemoveUserInterface()
RemoveMenus();
RemoveToolbar();
void Cswobj::AddMenus()
long retval = 0;
VARIANT_BOOL ok;
long type;
long position;
CComBSTR menu;
CComBSTR method;
CComBSTR update;
CComBSTR hint;
// Add menu for main frame
type = swDocNONE;
position = 3;
menu.LoadString(IDS_MY1_MENU);
m_iSldWorks->AddMenu(type, menu, position, &retval);
position = -1;
menu.LoadString(IDS_MY1_START_NOTEPAD_ITEM);
method.LoadString(IDS_MY1_START_NOTEPAD_METHOD);
hint.LoadString(IDS_MY1_START_NOTEPAD_HINT);
m_iSldWorks->AddMenuItem2(type, m_swCookie, menu, position, method, update, hint, &ok);
position = -1;//wb
menu.LoadString(IDS_111_ITEM);
method.LoadString(IDS_111_METHOD);
hint.LoadString(IDS_111_HINT);
// Add menu for part frame
type = swDocPART;
position = 5;
position = -1;//wb
position = -1;//wb
menu.LoadString(IDS_111_ITEM2);
method.LoadString(IDS_111_METHOD2);
hint.LoadString(IDS_111_HINT2);
position = -1;
// Add menu for assembly frame
type = swDocASSEMBLY;
position = 5;
position = -1;
// Add menu for drawing frame
type = swDocDRAWING;
position = 5;
position = -1;
void Cswobj::RemoveMenus()
VARIANT_BOOL ok;
CComBSTR menu;
m_iSldWorks->RemoveMenu(swDocNONE, menu, NULL, &ok);
m_iSldWorks->RemoveMenu(swDocPART, menu, NULL, &ok);
m_iSldWorks->RemoveMenu(swDocASSEMBLY, menu, NULL, &ok);
m_iSldWorks->RemoveMenu(swDocDRAWING, menu, NULL, &ok);
void Cswobj::AddToolbar()
VARIANT_BOOL stat = VARIANT_FALSE;
VARIANT_BOOL ok;
HRESULT hres;
CComBSTR title;
CComBSTR callback;
CComBSTR update;
CComBSTR tip;
CComBSTR hint;
if (m_lToolbarID == 0)
title.LoadString(IDS_MY1_TOOLBAR_TITLE);
callback.LoadString(IDS_MY1_TOOLBAR_CALLBACK);
update.LoadString(IDS_MY1_TOOLBAR_UPDATE);
tip.LoadString(IDS_MY1_TOOLBAR_TIP);
hint.LoadString(IDS_MY1_TOOLBAR_HINT);
hres = m_iSldWorks->AddToolbar3(m_swCookie, title, IDR_TOOLBAR_SMALL, IDR_TOOLBAR_LARGE, -1,
swDocTemplateTypeNONE|swDocTemplateTypePART|swDocTemplateTypeASSEMBLY|swDocTemplateTypeDRAWING, &m_lToolbarID);
m_iSldWorks->AddToolbarCommand2(m_swCookie, m_lToolbarID, 0, callback, update, tip, hint, &ok);
m_iSldWorks->AddToolbarCommand2(m_swCookie, m_lToolbarID, 1, callback, update, tip, hint, &ok);
m_iSldWorks->AddToolbarCommand2(m_swCookie, m_lToolbarID, 2, callback, update, tip, hint, &ok);
void Cswobj::RemoveToolbar()
if (m_lToolbarID != 0)
VARIANT_BOOL stat;
HRESULT hres = m_iSldWorks->RemoveToolbar2( m_swCookie, m_lToolbarID, &stat);
m_lToolbarID = 0;
// ISwAddin implementation
STDMETHODIMP Cswobj::ConnectToSW(IDispatch * ThisSW, LONG Cookie, VARIANT_BOOL * IsConnected)
VARIANT_BOOL status;
if (IsConnected == NULL)
return E_POINTER;
m_swCookie = Cookie;
m_iSldWorks = CComQIPtr<ISldWorks, &__uuidof(ISldWorks)>(ThisSW);
if (m_iSldWorks != NULL)
m_iSldWorks->SetAddinCallbackInfo((long)_Module.GetModuleInstance(), static_cast<Iswobj*>(this), m_swCookie, &status);
AddUserInterface();
return S_OK;
STDMETHODIMP Cswobj::DisconnectFromSW(VARIANT_BOOL * IsDisconnected)
if (IsDisconnected == NULL)
return E_POINTER;
RemoveUserInterface();
m_iSldWorks.Release();
return E_NOTIMPL;
// DSldWorksEvents implementation
// Iswobj implementation
STDMETHODIMP Cswobj::StartNotepad()
// TODO: Add your implementation code here
::WinExec("Notepad.exe", SW_SHOW);
return S_OK;
STDMETHODIMP Cswobj::ToolbarUpdate(long *status)
HRESULT retval = S_OK;
*status = 1;
return S_OK;
STDMETHODIMP Cswobj::first()//新建文件
AFX_MANAGE_STATE(AfxGetStaticModuleState())
HRESULT retval;
CComPtr<IPartDoc>pPartDoc = NULL;
retval = m_iSldWorks->NewPart((IDispatch**)&pPartDoc);
if(pPartDoc == NULL)
AfxMessageBox(_T("新建零件文件失败"));
return S_FALSE;
return S_OK;
STDMETHODIMP Cswobj::second()//创建圆柱
VARIANT_BOOL bRetval = VARIANT_FALSE;
CComPtr<IModelDoc2> swDoc;//定义ModelDoc对象
CComPtr<IModelDocExtension> swDocExt;//定义ModelDocExtension对象
CComPtr<IFeatureManager> swFeatMgr;//定义FeatureManager对象
m_iSldWorks->get_IActiveDoc2(&swDoc);///获得当前活动文档对象
swDoc->get_Extension(&swDocExt);///获得当前ModelDocExtension对象
swDoc->get_FeatureManager(&swFeatMgr);///获得当前特征管理器对象
CComPtr<ISketch> swSketch;//定义Sketch对象
swDoc->IGetActiveSketch2(&swSketch);///获得当前激活的草图对象
if (swSketch == NULL)///如果当前没有激活的草图对象
swDocExt->SelectByID2(L"Front Plane", L"PLANE", 0.0, 0.0, 0.0, VARIANT_FALSE, 0, NULL, swSelectOptionDefault, &bRetval);///选择前视基准面
swDoc->InsertSketch2(VARIANT_TRUE);///添加草图
CComPtr<ISketchSegment> swSkSeg;//定义SketchSegment对象
swDoc->ICreateCircle2(0.0, 0.0, 0.0, 0.050, 0.0, 0.0, &swSkSeg);///新建一个圆
CComPtr<IFeature> swFeat;//定义Feature对象
swFeatMgr->FeatureExtrusion2(VARIANT_FALSE, VARIANT_FALSE, VARIANT_FALSE,0, 0, 0.100, 0.100,///拉伸
VARIANT_FALSE, VARIANT_FALSE, VARIANT_FALSE, VARIANT_FALSE, 0.0, 0.0,
VARIANT_TRUE, VARIANT_FALSE, VARIANT_TRUE, 0, 0.0, VARIANT_FALSE, &swFeat);
return S_OK;
还要学习高级编程语言,搞这么复杂,主要用在什么方面? 看的眼都花了 尤记哪年哪月学过c语言 c++好像成绩还不错 现在这 扎一看 不明觉厉a 二次开发对复杂装配体的变型设计才有用吧,单个零件拿来干嘛,做重构库? 额,我做过VB的SolidWorks二次开发。C++的不会,跟你说一下VB下的SolidWorks二次开发大致思路吧,希望对你有些帮助。我当时做的时候,是通过录制宏及查阅API的help文档做的,单个零件建模的话,其实就是不断的草图绘制和特征建立,而这里面最难的就是草图、基准面什么的选取,找准ID就好了,你可以录制macro文件之后看看。至于你说的这个轮毂的建模,难度应该不大,就只是工作量的问题。 弱弱的问一句,为啥要用二次开发画呢?这玩意不是能直接画出来吗?好像也不是特别难得样子啊。。。小白我完全不会用二次开发,但是感觉好像也能画出来。 喂我袋盐 发表于 2016-1-10 23:39 static/image/common/back.gif
这个好搞零件库 余存 发表于 2016-1-11 11:35 static/image/common/back.gif
弱弱的问一句,为啥要用二次开发画呢?这玩意不是能直接画出来吗?好像也不是特别难得样子啊。。。小白我完 ...
要弄零件库,和各种轮胎装配 Brian_Hou 发表于 2016-1-11 11:00 static/image/common/back.gif
额,我做过VB的SolidWorks二次开发。C++的不会,跟你说一下VB下的SolidWorks二次开发大致思路吧,希望对你有 ...
初学小弟感觉很难啊
