寂静天花板 发表于 2015-8-12 19:17:57
solidworks概念设计让你永远不失去你的设计数据
Karl W. Schmidt started usingdata management technology three years ago with the introduction of SOLIDWORKSEPDM. Data management was implemented due to the number of components we workwith on our systems. For those of you that do not know us, Karl W. Schmidt is aglobal leader in engineering and manufacturing of custom recycling systems. Ourproducts are large – both in physical size and by number of components inassembly. It is challenging to keep track of all the data created by everyone.Using SOLIDWORKS EPDM, we are able to internally connect all the differentfiles created by our team. Our large projects can be up to 50,000 components inCAD alone.
使用solidworks enterprise PDM好处,保障了公司使用5000个部件作大项目。
When we started using theSOLIDWORKS 3DEXPERIENCE products two years ago, we had to ask ourselves: Howwill all of our current data work with this new technology, and can we developa system where we seamlessly use our data internally for manufacturing, whiletaking advantage of SOLIDWORKS Conceptual Designer, and keep data in the cloudfor easy access anytime from anywhere by our customers and vendors? Through alittle trial and error we were able come up with a system to use both toolstogether in harmony. Below is a quick breakdown of how we use each tool tosimplify and streamline our process from customer engagement throughmanufacturing.
两年前开始solidworks 概念设计,原先公司内部开发了一个系统,保障数据的无缝连接。现在使用solidworks概念设计,数据保存在云上,方便让公司和客户在任何地方访问数据。如何让这两种工具相安无事,下面是个案例。
1)Withboth PDM and cloud-based 3DEXPERIENCE solution in our environment, we had todetermine where the “top” level files would reside.PDM和3D体验平台云计算共存于一家公司,必须从顶层设计开始。In the beginning of each projectwe work very closely with our customers, vendors and prospects on collectingtheir requirements and proposing the solution that would fit their needs. Weuse SOLIDWORKS 3DEXPERIENCE products during the sales cycle because they handleall the data during this phase of the project, and the cloud nature of theproduct enables easy collaboration with customers, etc. As we design the newproduct and work on different concepts, the 3DEXPERIENCE platform providestransparent data management on the cloud with little or no intervention fromus. The system ensures that all of the models and data created are always safeand always available to me, my team (regardless if they are in the office or atcustomer site), and most importantly – available to our customers andprospects.
在项目开始阶段,密切联系客户、供应商,收集他们的要求和建议,提供符合他们需求的解决方案。这时使用solidowrks 3D体验平台产品,因为在项目的这一阶段处理他们所有的数据,产品的性质决定了云计算能够与客户等容易合作为我们设计新产品。
3D体验平台提供的云计算透明的数据管理,我们这里很少或根本没有干预的。该系统可确保所有的模型和创建的数据始终是安全的,而且总是提供给我及我的团队(不管他们是在办公室还是在客户现场),以及最重要的 - 提供给我们的客户和潜在客户。
Once the sales cycle is completedand the project is ready to be processed for manufacturing, we transfer thedata to EPDM to begin our manufacturing process. For example, the finishedcustomer approvals, emails, and CNC programs all end up in SOLIDWORKS EPDM. Wedo this based on many factors including using SOLIDWORKS EPDM in our shop atthe laser and CNC press brakes so they can pull up 3D models on the fly todouble check the parts being created in real time. They also use EPDM todownload any programs and setup sheets as they work.
一旦完成这一周期,项目准备制造了,我们将数据传输到 enterprisePDM开始我们的制造工艺。例如,在SolidWorks EPDM客户完成审批,电子邮件,以及CNC程序编制。我们这样做是基于许多因素,包括我们在激光和数控折弯机车间使用SolidWorksenterprise PDM,使他们能够拉起3D模型,仔细检查这些部件的实时创建。他们还使用enterprisePDM为他们的工作下载任何程序和设置表。
2)Thenumber one question we have gotten a lot over the last two years is: Howdo you transfer the data back and forth? Actually, we have a couplemethods depending on whether we use SOLIDWORKS 2015 or SOLIDWORKS ConceptualDesigner.2)我们已经解决了很多问题,在过去两年的头号问题就是:你如何来回传输数据?其实,我们有几个方法,这取决于我们是否使用SolidWorks2015或SolidWorks概念设计。If we are creating small projectsthat use our “standard” components from the EPDM Masters, we simply use theSOLIDWORKS Connector to upload the files to the customer’s 3D space.
如果我们正在创建使用我们的“标准化”的enterprisePDM小项目,我们只需使用SolidWorks连接器将文件上传到客户的三维空间。
As you can see by the images,everything works just like anyone using SOLIDWORKS would be used to. You canopen, close, save files without even thinking about the data managementhappening in the background. The task pane shown below on the right, allows youto control data just like you would with any data management system.
正如你可以在图片看到,一切工作就像使用SolidWorks任何人都会被用来。您可以打开,关闭,保存文件,甚至没有考虑数据管理发生的背景。在下面右图所示的任务窗格,使您能够控制数据,就像对待任何其他PDM系统。
When we use SOLIDWORKS ConceptualDesigner, we can work in the same fashion with all the files as well.
当我们使用SOLIDWORKS概念设计,我们可以以相同的方式工作,与所有的文件。
3)Thesecond question we usually get when speaking with people is: “Howdo you find your data?” Since it’s a cloud solution, finding datawith SOLIDWORKS Conceptual Designer is easy. As a user you are always connectedto the latest information and versions of your designs – I can access thisinformation anytime from anywhere. One of the features I like most about the3DEXPERIENCE technology is the ability to find your data in a couple differentways. You can find it in either CAD application or directly through the 3Dspace and communities. This allows you to find data through any device that isconnected to the internet in a secure and safe way. This is very useful for uswhen we are out in the field working with installers and customers.3)我们通常会与人对话时的第二个问题是:“你怎么找到你的数据?”因为它是一个云解决方案,所以用SolidWorks概念设计寻找数据是很容易。作为一个用户,你总是连接到最新的信息和你的设计版本 - 我可以从任何地方随时访问这些信息。其中我最喜欢的3D体验平台技术的特点是要找到你的数据在几个不同的方式的能力。你可以找到它在任一CAD应用程序或直接通过3D空间和社区。这使您可以通过连接到互联网的安全和安全的方式任何设备查找数据。当我们在现场与安装商和客户合作这对我们来说是非常有用的。
The way we can find our data isby using “Tags” within the 3D EXPERIENCE application. These tags are set upusing the 6 w’s we all learned about at some point in our lives – who, what,when, where, why & how. The system creates some of these tags automaticallybased on “who” is working on “what” and “when.” We also create additional tagsfor different parts and components in order to capture additional informationwe need. These tags can be added on the fly at any point in data creation. Byhaving this flexibility we can easily narrow down a search to quickly find anydata.
我们可以发现我们的数据的方法是使用3D体验平台上的“标签”应用程序。这些标签设置使用我们都在我们的生活中了解到6W方法来识别公司,who,what, when, where, why & how。系统会根据on “who” is working on “what” and“when.”自动创建一些标签。我们也为不同的零部件创造更多的标签,以便捕捉我们需要更多的信息。这些标签可以在数据创建任何点加入。由于具有这种灵活性,我们可以很容易地缩小搜索快速找到任何数据。
In summary, the basis of ourbusiness success is flexibility. Most of our customers are constantly lookingfor new ways to improve the recycling process. Whether they are looking toimplement a brand new system, replace conveyors or introduce better methods ofsorting, one thing is a constant: everything evolves.As manufacturers of this technology, we mustconstantly evolve and look for technology that allows us to develop solutionsfaster than the competition.The data managementtools within the 3DEXPERIENCE platform coupled with SOLIDWORKS EPDM allow us tohave the right solutions at the right time.
总之,我们业务成功的基础是灵活性。我们的大多数客户都在不断寻找新的方法来改善回收过程。无论他们是否实现了一个全新的系统,更换传送带或引进排序的更好的方法,有一点是不变的:一切都在变。随着使用这项技术的厂商越来越多,我们必须不断发展,并寻求技术,使我们能够比竞争对手更快发展的解决方案。在3DEXPERIENCE平台加上SOLIDWORKS Enterprise PDM内的数据管理工具,使我们能够在正确的时间使用正确的解决方案。
查看完整版本: solidworks概念设计让你永远不失去你的设计数据
