各位大侠助我翻译句话,英语
各位大侠助我翻译句话,英语。前车轴右侧止推轴承损坏,轴端接触有磨损。后车轴左侧转向离合器齿轮轻微磨损,其它皆完好。The thrust bearing on the right side of the front axle has failed,wear exists in the contact area of the front axle ends(轴端接触不是很确定) and the gears of the steering clutch on the left side of the rear axle wear slightly,anything else are all okay.
非专业人士,仅供参考。 内容学习了 内容学习了
