寂静天花板 发表于 2015-2-6 16:34:41
预热solidworks world 2015——回顾历年十大用户建议的官方采纳率
每一年,SOLIDWORKS world都有十大用户建议倒计时。在SOLIDWORKS world前几个月中,有创意的用户通过官方论坛提交给solidworks world 十大建议。从12月中旬开始,用户有机会投票他们最希望的想法。排名前十位投票结果将显示在那一年的SOLIDWORKS world的大舞台。这份名单由每年不同的新的增强功能实现或客户需求的变化。有些想法也重新出现在列表中的前几年。排名前十位的最高票获得的想法是从零件,图纸,组件,以及其他方面的总和。我们可以只显示前十大图纸的想法。图纸包括主题,如BOM表,标注,尺寸等,现在我们看看SolidWorks world 2011的十大用户建议1 Ability to Filter BOMs2 Print Selection – make it more like cropping a picture3 On drawings: add function to allow users to apply capitalization of text, solidworks 2013已实现4 Assign watermark function to drawing sheets, solidworks 2013已实现5 Allow Multiple Exploded Views per Configuration, solidworks 2013已实现6 More control over angle dimensions, solidworks2015已实现7 On drawings: Allow option for resizing of drawing view outline 8 Directly editing notes with properties in Drawing, implemented solidworks2012已实现9 Broken-out Section in Section, Detail and Alternate Positions Views10 Better line selection in drawings, solidworks2014已实现官方采纳率约为60%Solidworks world 2012的十大用户建议1Address Shaded with Edges Bleed Thru issue solidworks2014已实现 2Dimensions should stay where you place them 这个建议其实是个怪胎,因为solidworks早就能实现了,只是在系统选项中的称号与用户的不一致,导致了一个乌龙。3Don't show hidden lines in section views and broken-out sections solidworks2013部分实现4Don’t re-size center marks with scale of drawing view or sheet-5Allow multiple exploded views per configuration 听上去很熟悉吧,这是2011年的十大建议之一,已在solidworks2013中实现6Drawings: make intersection selectable when dimensioning drawings solidworks2014已实现7Ability to create a “purchased” component BOM and “manufactured” component BOM 8Drawings: Revision Cloud solidworks2013已实现9Dashes should not be allowed at the end of a line 10Parts as references in drawing views 这个建议从标题上看,与其实际表达的内容完全相反,所以教训是提交你的想法时,使用一个明确的标题如果排除2 3 10的几个建议,官方采纳率为60%Solidworks world 2013十大用户建议 高度集中于图纸尺寸和图纸视图1 Create auxiliary line for dimensioning angles 已在solidworks2015中实现2 Perimeter Dimension or Total Length Dimension 3 Allow mirroring of drawing views in the drawing4 Isometric view break5 Ability to create half dimensions (Option to change any dimension line to foreshortened)6 On drawings, zoom to fit should ignore view bounding boxes 已在solidworks2015中实现7 Don’t re-size center marks with scale of drawing view or sheet8 Ability to create Alternate position view on sectioned/broken-out section view9 Make an easy interface to modify format of hole callouts (without having to edit calloutformat.txt)10 Projected view of a break view should have option ‘align breaks with parent’ enabled by default官方采纳率为20%
水水5 发表于 2015-2-6 19:03:00
英文太差,一点也看不懂,
求高手翻译
查看完整版本: 预热solidworks world 2015——回顾历年十大用户建议的官方采纳率
