hejun502 发表于 2015-1-18 13:38:25
运行ANSYS workbench 的时候老是说内存不足
每次运行都出现以下情况,求助 There is not enough memory for the Sparse Matrix solver to proceed.
This is likely due to the use of pivoting while factoring the matrix.
The solver will now attempt to allocate additional memory and restart
the factorization step.If this fails, please increase the virtual
memory on your system and/or increase the work space memory and rerun
ANSYS.The memory currently allocated for the Sparse Matrix solver =
942 MB.
虚拟内存小了吗?我设置的是500-23500
硬盘内存33.4G
我都要疯了,求助求助
筱羽 发表于 2015-1-18 14:57:35
你这个内存是指内存条,不是硬盘的容量,建议再插个内存条组双通道吧。
hejun502 发表于 2015-1-18 15:20:57
筱羽 发表于 2015-1-18 14:57 static/image/common/back.gif
运行内存吗?12G的运行内存应该不小了吧
那是什么原因啊?我都困扰好几天了
筱羽 发表于 2015-1-19 09:46:35
hejun502 发表于 2015-1-19 09:15 static/image/common/back.gif
那是什么原因啊?我都困扰好几天了
http://wenku.baidu.com/link?url=r00xnXFBEOB6hwg_yQvbua-jIeksj6J3bD4Kwnl7gngM5RnsoMMeeodvkrTV7gcNj67Sxcis7_AKswL4piS66JFUgok0fzOhJce6rRPOIrW
你看看这个或许对你有帮助。
hejun502 发表于 2015-1-19 13:41:16
筱羽 发表于 2015-1-19 09:46 static/image/common/back.gif
http://wenku.baidu.com/link?url=r00xnXFBEOB6hwg_yQvbua-jIeksj6J3bD4Kwnl7gngM5RnsoMMeeodvkrTV7gcNj6 ...
根据上面提示的设置,对workbench有用吗?我怎么感觉是对经典的有用的
ljllaile 发表于 2018-7-19 14:42:44
建议网格化稀疏点试试看
查看完整版本: 运行ANSYS workbench 的时候老是说内存不足
