hgt04qy 发表于 2006-5-21 14:03:34
数控车高级(实操题)
<P>图纸见附件</P>
<P>一号刀:偏刀<BR>二号刀:切断刀<BR>三号刀:螺纹刀</P>
<P>&nbsp;</P>
<P>N10 M03 S2<BR>N20 T0101<BR>N30 G00 X31 Z0<BR>N40 G71 U1.0 R0.5<BR>N50 G71 P60 Q120 U0.4 F50<BR>N60 G01 X0 F30<BR>N70 X2.163 Z-1.873 <BR>N80 G02 X12.792 Z-7.26 R15<BR>N90 G03 X25 Z-18 R12.5<BR>N100 G01 Z-35<BR>N110 X28<BR>N120 Z-69.5<BR>N130 G00 X50 Z80 M05<BR>N140 M00<BR>N150 M03 S1<BR>N160 T0101<BR>N170 G00 X30 Z0<BR>N180 G70 P60 Q100<BR>N190 G00 X50 Z80 M05<BR>N191 M00<BR>N192 M03 S1<BR>N194 T0101<BR>N196 G00 X30 Z0<BR>N197 G70 P60 Q100<BR>N198 G00 X50 Z80 M05<BR>N200 M00<BR>N210 M03 S2<BR>N220 T0202<BR>N230 G00 X30 Z-30.9<BR>N240 G01 X15.5 F15<BR>N250 G00 X30<BR>N260 G72 W3 R0.5<BR>N270 G72 P280 Q330 U0.2<BR>N280 G00 Z-17.5<BR>N290 G01 X25 F15<BR>N300 Z-18<BR>N310 G03 X17.857 Z-26.748 R12.5<BR>N320 G02 X15 Z-30.247 R5<BR>N330 G01 Z-30.98<BR>N340 G00 X50 Z80 M05<BR>N350 M00<BR>N360 M03 S1<BR>N370 T0202<BR>N380 G00 X30 Z-30.9<BR>N390 G70 P280 Q330<BR>N392 G00 X50 Z80 M05<BR>N394 M00<BR>N396 M03 S2<BR>N398 T0202<BR>N400 G00 X30 Z-50<BR>N410 G75 X20 Z-65 P2000 Q3500 F15<BR>N420 G01 X10.5<BR>N430 G00 X30 <BR>N440 G72 W3 R0.5<BR>N450 G72 P460 Q492 U0.2<BR>N460 G00 Z-34.5<BR>N470 G01 X28 F15<BR>N480 Z-39.412<BR>N490 G03 X15.774 Z-50 R15<BR>N492 G01 X10<BR>N500 G70 P460 Q490<BR>N600 G00 Z-50.98<BR>N610 G01 X10.5 F15<BR>N612 X10<BR>N620 Z-50<BR>N630 G00 X18 Z-50.98<BR>N640 G01 X19.8 Z-51.98<BR>N650 Z-64<BR>N660 X18 Z-65<BR>N660 X17<BR>N660 G00 X50<BR>N670 Z80 M05<BR>N680 M00<BR>N690 M03 S1<BR>N700 T0303<BR>N710 G00 Z-55<BR>N720 X20<BR>N730 G92 X19.3 Z-65 F1.5<BR>N740 X18.8<BR>N750 X18.6<BR>N755 X18.4<BR>N756 X18.3<BR>N760 X18.2<BR>N770 X18.1<BR>N780 X18.05<BR>N790 G00 X50<BR>N800 Z80 M05<BR>N810 M00<BR>N820 M03 S2<BR>N830 T0202<BR>N840 G00 Z-65<BR>N850 X20<BR>N860 G01 X2.5 F15<BR>N870 G00 X50<BR>N880 Z80 M05<BR>N890 T0100 M30</P>
<P>&nbsp;</P>
ljc11383 发表于 2006-5-23 18:49:53
Re: 数控车高级(实操题)
G00X100Z100                     设定坐标
S2M3T0202                     560转主轴低速正转,2号粗车刀
G00X32Z2M08
G73U14W0R0.007
G73P1Q2U0.3W0F100
N1G01X0Z0F40
X2.16Z-1.87
G02X12.79Z-7.26R15F30
G03X17.86Z-26.75R12.5   (如有偏差可将此值适当增大,根据误差来确定)
G02X15Z-30.25R5
G01Z-35F40
X27
X28Z-35.5
Z-40
G03X16.45Z-50R15F30   (如有偏差可将此值适当调整,根据误差来确定)
G01Z-55F40
X19.8
Z-70
G00X100Z100M05
M00
S1M3T0101
G0X32Z2M08
G70P1Q2
G00X100Z100M05
M00
S2M3T0303
G00X29Z-52M08
G76P030060Q10R0.01
G76X18.05Z-66P975Q250F1.5
G00X100Z100M05
M00
S2M3T0404
G00X29Z-50M08
G01X10.1F40
G00X29
Z-51.8
G01X10F30
Z-50
G00X100
Z100M05
M00
S2M3T0404
G00X29Z-65M08
G01X0F40
G00X100
Z100M05
T0101
M30
1号刀为90度,副偏角60度的精车刀;
2号刀为90度,副偏角60度的粗车刀;
3号刀为60度的高速钢螺纹车刀;
4号刀为刀宽3.2MM的高速钢槽刀;
这是我用G73编的,请大家多多指教.....
ljc11383 发表于 2006-5-23 18:50:22
Re: 数控车高级(实操题)
N1 G00X100Z100                     设定坐标
N2 S2M3T0202                     560转主轴低速正转,2号粗车刀
N3 G00X32Z2                        快速定位
N4 G90X28.5Z-75F100               粗车零件轮廓,留余量0.5MM
N5 G00X28.5
N6 G90X25.5Z-35
N7 G00X25.5
N8 G90X24.44Z-14.35
N9 G00X24.44
N10 G90X20.44Z-10.37
N11 G00X20.44
N12 G90X16.44Z-8.25
N13 G00X16.44
N13 G90X12.44Z-6.86
N14 G00X12.44
N15 G90X8.44Z-5.35
N16 G00X8.44
N17 G90X4.44Z-3.15
N18 G00X0.5Z0.13
N19 G01X2.6Z-1.75
N20 G02X13.04Z-7.05R14.75
N21 G3X25.5Z-18R12.75
N22 G0X100Z100M05                        返回参考点,主轴停止
N23 M00                                        程序暂停
N24 S2M3T0404                         560转低速正转,4号切槽刀
N25 M08                                        冷却液开
N26 G00X29Z-31.8                     用3个G72粗车循环指令,
N27 G01X15.5F40                        对三外轮廓进行粗车,
N28 G00X29                              留余量0.5MM
N29 G72W2.5R0.5
N30 G72P31Q35U0.5W0F30
N31 G00Z-18
N32 G01X25F40
N33 G03X17.86Z-26.75R12.5F30
N34 G02X15Z-30.25R5F30
N35 G01Z-31.8F40
N36 G00Z-51.8
N37 G01X10.5F40
N38 G00X29
N39 G72W2.5R0.5
N40 G72P41Q45U0.5W0F40
N41 G00Z-40
N42 G01X28F40
N43 G03X16.45Z-50R15F30
N44 G01X10F40
N45 Z-51.8
N46 G00Z-65
N47 G01X18F40
N48 G00X29
N49 G72W2.5R0.5
N50 G72P51Q53U0.5W0F40
N51 G00Z-55
N52 G01X19.8F40
N53 Z-65
N54 G00X100Z100                              返回参考点
N55 S1M3T0101心                     1120转主轴高速正转,1号精车刀
N56 G00X-0.5Z2                                  快速定位
N57 G01X0Z0F40                              精车零件轮廓
N58 X2.16Z-1.87
N59 G02X12.79Z-7.26R15F30
N60 G03X17.86Z-26.75R12.5             (如有偏差可将此值适当增大)
N61 G02X15Z-30.25R5
N62 G01Z-35F40
N63 X27
N64 X28Z-35.5
N65 Z-40                               (如有偏差可将此值适当调整)
N66 G03X16.45Z-50R15F30
N67 G01Z-55F40
N68 X19.8
N69 Z-65
N70 G00X100Z100                                 返回参考点
N71 S2M3T0303                           560转低速正转,3号螺纹刀
N72 M08                                          冷却液开
N73 G00X29Z-52                                 快速定位
N74 G76P050060Q10R0.01                     粗精车M20X1.5螺纹
N75 G76X18.05Z-66P975Q250F1.5
N76 G00X100Z100                              返回参考点
N77 S2M3T0404                            560转低速正转,4号切槽刀
N78G00 X29Z-50                                  返回参考点
N79 G01X10F40                                  精车 10槽处
N80 Z-51.8
N81 G00X100
N82 Z100M05                              返回参考点,主轴停止
N83 M00                                           程序暂停
N84 S2M3T0404                            560转低速正转,4号切槽刀
N85 G00X29Z-65                                    快速定位
N86 G01X0F40                                        切断工件
N87 G00X100
N88 Z100                                 返回参考点,主轴停止
N89 M05
N89 T0100                                 返回基准刀
N90 M30                                     程序结束
1号刀为90度,副偏        角60度的硬质合金精车刀;
2号刀为90度,副偏角6~8度的硬质合金,粗车刀;
3号刀为60度的高速钢螺纹车刀;
4号刀为刀宽3.2MM的高速钢槽刀;
注:第一件试切时,应在设置坐标(G50)处预留余量0.5MM。试切一遍后,再根据实际尺寸的偏差进行调整,把尺寸控制在公差范围内。
ljc11383 发表于 2006-5-23 18:52:14
Re: 数控车高级(实操题)
这是用G90和G72编程的,比用G73的粗车加工时间提高差不多两倍以上.
大家可以试试看....
请大家多多指教.....
ljc11383 发表于 2006-5-23 18:56:30
Re: 数控车高级(实操题)
因为不是用圆心编程,所以加工出来在圆球的部分和R15的部分会存在一定的误差.
本人用直接修改坐标的方法来进行补偿,用千分尺测量可以控制在公关范围内.
楼主可以做个朋友吗,我的QQ是84079975
hgt04qy 发表于 2006-5-23 20:14:29
Re: 数控车高级(实操题)
我认为: S指令跟T的指令最好是分为两段来写较安全一些
如 N1 M03 S500
    N2T0202
二楼的程序 G73后开始的第一行程序不能有Z 方向的,G71也一样,而G72后的第一行程序不能有X方向的。如果该工件用G73的话我建议分两段来要好一点,速度会快点。 还有我想问一下GSK980T有G76的吗?2号刀用90度,副偏角60度的粗车刀,强度够吗?
对于三楼的我觉得用G71要比用G90方便和省时间
ljc11383 发表于 2006-5-23 23:47:13
Re: 数控车高级(实操题)
实际加工用循环指令是比较少的,用单一循环指令比较多.
如果就单件加工来讲,用G71和G72会方便一些.
用G90和单段指令编程会麻烦一些,但在实际加工中效率就会体现出来的.
为了避免与工件产生干涉,所以副偏角要大一些.
G73的第一段是可以有X和Z的,你可以试一下阿!!
把S指令和T指令分开或合在一段都问题不大,系统会先S\T\G的顺序进行的.
ljc11383 发表于 2006-5-23 23:47:47
Re: 数控车高级(实操题)
各位高手们多多交流阿,学习中...
hgt04qy 发表于 2006-5-24 00:04:53
Re: 数控车高级(实操题)
不好意思,我因为在实际加工中没有用过G90,我只是从编程的角度来讲的,有机会我一定要试试。 阿承:你也在汕头? 我QQ241150329,有空的话大家一起研究
ljc11383 发表于 2006-5-24 12:43:30
Re: 数控车高级(实操题)
对阿,我是澄海的.不过现在在广州,楼主还要向你多多学习呢!!
页: [1] 2 3 4 5 6
查看完整版本: 数控车高级(实操题)
