查看: 5450|回复: 6
一篇关于医疗器械MR安全性的文章
发表于 2013-1-6 13:04:33 | 显示全部楼层 |阅读模式
Terminology With Regard to Magnetic Resonance Imaging (MRI) and Implants and Devices
MRI Labeling Information for Implants and Devices: Explanation of Terminology*! B  `: f2 l8 v8 q7 E
3 s, X' g( ~4 _# h: q  rSummary Statement. This Editorial presents the recommendations from the Food and Drug Administration for MR safety terminology and labeling for medical devices and provides an explanation of how this information is applied.
# x4 y# ~0 Y5 S) `
2 ^- L7 [5 D3 w7 E. C; H+ e0 nThe magnetic resonance (MR) environment may pose risks or problems to patients with certain implants and other medical devices primarily due to factors that include electromagnetic field interactions, MRI-related heating, and the creation of artifacts (1-5). In addition, for electrically-activated implants and other medical devices, there are concerns that the MR system may affect the operation of the medical device and/or to induce currents in the device (1-3, 5). With the growing use of MRI in the 1990s, the Food and Drug Administration (FDA) recognized the need for standardized tests to address MRI safety issues for implants and other medical devices (4, 6). Thus, over the years, test methods have been developed by various organizations including the American Society for Testing and Materials (ASTM) International (formerly the American Society for Testing and Materials), with an ongoing commitment to ensure patient safety in the MR environment (7-10).0 o2 {) O: d! D2 r
5 l$ c& }* b) q/ Q* L6 g! sThe FDA is responsible for reviewing the MR terminology and labeling that manufacturers provide to their devices. The MR terminology, as it pertains to performing MR examinations in patients with implants and other medical devices, has continued to evolve to keep pace with advances in MRI technology (4, 6, 11). Unfortunately, members of the MRI community frequently do not always understand the terms that are used and are often confused by the conditions that are specified in “MR Conditional” labeling. This lack of understanding may result in patients with implants being exposed to potentially hazardous MRI conditions or in inappropriately preventing them from undergoing needed MRI examinations. Importantly, there is now new labeling terminology, which is associated with expanded labeling information. Therefore, the goal of this Editorial is to present background information about the terms used for MRI labeling of implants and other medical devices, to define the current terms, and to illustrate the use of the new labeling by providing a sample label with a detailed explanation of how the terminology is used.% r, O- N! ~' e+ m% t
' Y% u, z' J$ lPrior Terminology
# n& z' Y5 B( Y8 d0 ~In 1997, the FDA’s Center for Devices and Radiological Health (CDRH) first proposed terms to be used to label MRI information for medical devices, which was presented in the draft document, “A Primer on Medical Device Interactions with Magnetic Resonance Imaging Systems (6). These terms were defined, as follows (6):7 \9 Z6 l2 V# F: e; g  _$ j
* q+ @/ |6 J8 X" e0 h* W. c
MR Safe: This term indicates that the device, when used in the MR environment, has been demonstrated to present no additional risk to the patient, but may affect the quality of the diagnostic information. 1 l( A+ V9 K! ?5 R7 n; L, \1 v
% Z3 F, R( U7 [- M1 l/ X. a
MR Compatible: This term indicates that the device, when used in the MR environment, is MR Safe and has been demonstrated to neither significantly affect the quality of the diagnostic information nor have its operations affected by the MR device.”; N0 h% o. S6 H+ ~7 ?
7 c7 k! O! w$ s$ Y) z
This document further stated that, “The use of the terms, "MR Compatible" and "MR Safe" without specification of the MR environment in which the device was tested should be avoided since interpretation of these claims may vary and are difficult to substantiate rigorously. Statements such as "intended for use in the MR environment" or similar claims along with appropriate qualifying information are preferred (i.e. test conditions should be specifically stated)(6).” Here, the term “MR environment” encompasses the static, gradient (time-varying), and RF electromagnetic fields that may impact an implant or device.
; `; Q5 \2 H) ~/ A1 n( s1 e+ B- x
$ h3 K% x8 \& J2 e5 @Using this terminology, MRI testing of an implant or device for “MR safety” involved in vitro assessments of static magnetic field interactions, MRI-related heating, and, in some cases, induced electrical currents (i.e., from gradient magnetic fields), while “MR compatibility” testing required all of these as well as characterization of artifacts. In addition, it may have been necessary to evaluate the effect of various MRI conditions on the functional or operational aspects of an implant or device (2, 3, 4, 6, 7-10).
3 ]6 ]) P. P# |, m4 U& u, O. I9 X1 j
Revised Terminology7 ?' E: `! \: l/ v- }9 h/ v
In time, it became apparent that the terms, “MR Safe” and “MR Compatible” were confusing and often used interchangeably or incorrectly (2-4, 11, 12). In particular, the terms were sometimes used without including the list of conditions for which the device had been demonstrated to be safe, in some cases inappropriately giving the impression that the device is “safe” or “compatible” in all MR environments. Therefore, in an effort to develop more appropriate terminology and, more importantly, because the misuse of these terms could result in serious accidents for patients and others in the MR environment, the MR Task Group of ASTM International Committee F04 on Medical and Surgical Materials and Devices developed standard ASTM F2503 which includes a new set of MR labeling terms with associated icons (4). The new terms defined in ASTM F2503 (released in August 2005) and currently recognized by the FDA are (11, 13), as follows:! P7 m5 r# P3 D- M, U6 s. L
9 E* D/ H3 K7 E+ u2 O' O
MR Safe - an item that poses no known hazards in all MRI environments. Using the terminology, “MR Safe” items are non-conducting, non-metallic, and non-magnetic items such as a plastic Petri dish. An item may be determined to be MR Safe by providing a scientifically based rationale rather than test data.8 c- Y4 S  |2 f1 h7 Q2 s% _9 ~, q
; R. P& Z$ G& T% m" V+ i6 R
MR Conditional - an item that has been demonstrated to pose no known hazards in a specified MR environment with specified conditions of use. “Field” conditions that define the MR environment include static magnetic field strength, spatial gradient magnetic field, dB/dt (time rate of change of the magnetic field), radio frequency (RF) fields, and specific absorption rate (SAR). Additional conditions, including specific configurations of the item (e.g., the routing of leads used for a neurostimulation system), may be required.
( V0 V) H' T* G* @* o0 n6 k4 Z3 _$ |, D' Y+ l. e5 R8 N
For MR Conditional items, the item labeling includes results of testing sufficient to characterize the behavior of the item in the MR environment. In particular, testing for items that may be placed in the MR environment should address magnetically induced displacement force and torque, and RF heating. Other possible safety issues include but are not limited to, thermal injury, induced currents/voltages, electromagnetic compatibility, neurostimulation, acoustic noise, interaction among devices, and the safe functioning of the item and the safe operation of the MR system. Any parameter that affects the safety of the item should be listed and any condition that is known to produce an unsafe condition must be described.
5 [& Q, x( }! `9 j
" i5 k; L7 O( o+ F2 I) uMR Unsafe - an item that is known to pose hazards in all MRI environments. MR Unsafe items include magnetic items such as a pair of ferromagnetic scissors.* z" _$ s9 c6 h8 S2 a. d
& @; e4 Q% P6 ]2 m  ]0 Y- XAssociated Icons. In addition to the terms, MR Safe, MR Conditional, and MR Unsafe, the ASTM International MR marking standard introduced corresponding icons, consistent with international standards for colors and shapes of safety signs (13). These icons are intended for use on items that may be brought into or near the MR environment as well as in product labeling for implants and other medical devices. The icons may be reproduced in color or in black and white, however, the use of color is encouraged because of the added visibility (13).
7 C1 n( _# \- y! r5 a7 F6 w& ~* Z
& T0 Y3 r5 ^: S  ?The “MR Safe” icon consists of the letters ‘MR’ in green in a white square with a green border, or the letters ‘MR’ in white within a green square. The “MR Conditional” icon consists of the letters ‘MR’ in black inside a yellow triangle with a black border. The “MR Unsafe” icon consists of the letters ‘MR’ in black on a white field inside a red circle with a diagonal red band. Importantly, for “MR Conditional” items, the item’s labeling must include the parameters and results used for testing that are sufficient to characterize the behavior of the item in the MRI environment (13).$ M) f6 A8 U9 z8 B2 s3 w
6 h# B, ^% [! ?& {+ C+ o, ^
Further details and a comprehensive discussion of the labeling applied to passive implants are presented in the recent FDA document, “Guidance for Industry and FDA Staff - Establishing Safety and Compatibility of Passive Implants in the Magnetic Resonance (MR) Environment” (11).# Z$ B  \1 F( G. U5 ^; K% @
$ ?0 e6 e. W8 Z* J0 [/ g/ B
Use of Terminology: Reasons for Confusion
. F* n0 A" G6 H8 }+ T8 CBecause of the variety of MR systems and MR conditions in clinical use today (e.g., ranging from 0.2- to 9.4-Tesla), the current terminology is intended help elucidate labeling matters for medical devices and other items that may be used in the MR environment to ensure the safe use of MRI technology. However, it should be noted that this updated terminology has not been applied retrospectively to the many implants and devices that previously received FDA approved labeling using the terms “MR Safe” or “MR Compatible” (in general, this applies to those objects tested prior to the release of the ASTM International standard for labeling, around August 2005).
+ D/ O6 p; D( O) Y* F' F: b
. A! U5 W2 \0 ]6 _2 O0 ?Therefore, this important point must be understood to avoid undue confusion regarding the matter of the labeling that has been applied to previously tested implants (i.e., labeled as “MR safe” or “MR Compatible”) versus those that have recently undergone MRI testing (i.e., now labeled as “MR Conditional”)(2, 3).1 L7 G" [. E4 b. }# C# I6 {
3 L+ f; }% R, G, i4 s; R
3 I" g. j1 ]. @( _: Q+ o0 ?
The labeling for medical devices that were appropriately labeled using the historical definitions for MR Safe or MR Compatible, including the list of conditions for which the device has been determined to be safe or compatible, is still accurate. Indeed, part of the confusion that exists on this matter is due to the use coexistence of the newer terminology with the prior labeling terminology.
. ?( ^. A9 @5 j( a' b4 L9 t( N: d8 r6 ~1 l/ ~7 O6 f! e( \
In order to eliminate this ongoing confusion, in 2005 FDA recognized the new set of terms in ASTM F2503 and asks manufacturers to use them for all new products. When manufacturers make a submission to FDA for an existing device, FDA requests the manufacturers of these previously approved devices update their labeling to use the new MR safety terminology. Labeling information for implants and other medical devices has been compiled and is available in published and on-line formats (2, 14). Specific testing and labeling for active implants (e.g., those involving electronics) is currently being developed by an ISO (International Standards Organization) – IEC (International Electrotechnical Commission) joint working group.
( s+ p+ O) }4 e7 Z- T+ `3 ^& M$ S& m$ \, l6 t; u5 Q* g4 v
MR Conditional Labeling Information: Explanation of the Content+ c6 ^- a. ]( k$ j  m. ~$ q" `9 ?
In addition to the frequent problems associated with understanding the MRI labeling, the actual content of the label is often misunderstood with respect to the conditions indicated for a given implant that is labeled “MR Conditional”. Therefore, the following is an example of “MR Conditional” labeling for an implant, Example Implant, along with an explanation of the content, provided for each aspect of the label (1-4, 11, 13) (Table 1):
4 J( c  J' S3 s: Q# [' ?7 i' b; ]2 \# J7 @/ X) d, r- U4 ]
MRI Information
7 M6 U5 Z, k! ONon-clinical testing has demonstrated the Example Implant is MR Conditional. It can be scanned safely under the following conditions: 6 `6 u* B0 \8 X* E0 H; H, f% g
8 u5 i$ c  }" @; }) C-Static magnetic field of 3-Tesla4 `& M. M8 T! e
This is the static magnetic field for which the implant gave acceptable test results, generally the largest static magnetic field used for testing the implant. In some cases the labeling will state, “Static magnetic field of 3-Tesla or less” or “Static magnetic field of 3-Tesla, only” or “Static magnetic field of 1.5-Tesla or 3-Tesla.” Therefore, carefully reading and implementing this portion of the labeling for the implant is advised in order to avoid possible injuries to patients.& O* q5 R- o1 f; U, w1 L
* ]6 Q, K7 o; B  r: I% @-Spatial gradient magnetic field of 720-Gauss/cm or less.( g6 o/ @8 l# D2 L, w
This is a frequently misinterpreted parameter because the MRI user sees the term “gradient field” and presumes that it refers to the time-varying or gradient fields used during MR imaging. However, the term, “spatial gradient magnetic field” for medical device labeling relates to the rate at which the static magnetic field strength changes over space per unit length (thus, indicated as dB/dx or, in this case, as 720-Gauss/cm for this example). Notably, the point of the highest spatial magnetic gradient is the position where translational attraction (i.e., determined using the deflection angle method) is typically assessed for an implant or device, according to ASTM F2052 - 06e1. The MR system manufacturer is able to provide spatial gradient magnetic field information for a particular MR system or it may determined using a Gauss meter.$ U: H7 i% e4 K* N
5 s! Q% n2 y5 P2 U; u% Q, j0 [
8 m6 K  v- p5 m7 r* E-Maximum MR system reported, whole body averaged specific absorption rate (SAR) of 2-W/kg for 15-minutes of scanning.
4 W. F& M0 j" {3 `" q7 M4 IConfusion commonly exists with respect to this stated parameter insofar as the term “scanning” is presumed to apply to the entire MRI procedure when, in fact, it applies to only each particular pulse sequence that is used and, of course, multiple sequences are utilized when performing the MRI examination. Therefore, to adequately safeguard the patient, the whole body averaged SAR for each scan sequence must be maintained at or below 2-W/kg for each scan sequence. 4 K0 J, {9 H3 w
5 @1 r1 |  H5 Q* A* O
-In non-clinical testing, the Example Implant produced a temperature rise of less than 2.0°C at a maximum MR system reported, whole body averaged specific absorption rate (SAR) of 2- W/kg for 15 minutes of MR scanning in a (static magnetic field strength ________) (model ______) (MR system manufacturer ________) (software version _______) MR scanner. ! a. K- u" W- u% a, g
5 X. ?- s. e- x# ^* QThe labeling for the implant has additional information with respect to the temperature rise that is associated with certain MRI parameters, that is based on the findings obtained in the MRI-related heating test. Therefore, as seen in this example, the expected “worst case” temperature rise is 2.0 degrees C or less during MRI performed at a whole body averaged SAR of 2-W/kg for 15-min., using a particular MR system type (i.e., with the make, model, and software of the scanner indicated). The MR system reported, whole body averaged SAR of 2-W/kg is the level specified in the ASTM F2182 - 02a and is the level commonly reported in device labeling, although higher or lower SAR levels may also be indicated. (It should be noted that, in this labeling section, certain labels for implants and other medical devices may state that this information applies to the use of a particular type of transmit RF coil that should be used, such as a transmit body or transmit head RF coil.), A& I) x) K: k# \2 L
# W- S* D7 x) Z0 _( Q* T
Image Artifact
6 b) W2 n+ i% f& n, E/ eMR image quality may be compromised if the area of interest is in the same area or relatively close to the position of the device. Therefore, it may be necessary to optimize MR imaging parameters for the presence of this implant.
: u7 [* Q! g, t5 k- G5 {
2 P/ ~5 w+ {5 J* h& I9 PThis is a common statement for many different implants and devices. Since the size of the artifact for an implant or device may impact the diagnostic use of MR imaging, information is typically provided in the label that characterizes the size and shape of the artifacts associated with certain pulse sequences (e.g., T1-weighted spin echo and gradient echo), according to ASTM F2119 - 07 or an equivalent method. For devices with a lumen (e.g., stent), the labeling may indicate whether the lumen is obscured by the size of the artifact. 6 U- N5 G5 G+ P5 F3 c
$ R2 W: a2 W3 V! bThe FDA also recommends that the patient register the conditions under which their MR Conditional implant can be scanned safely with the MedicAlert Foundation or other equivalent organization, and so the device labeling may include contact information for MedicAlert (11).
! f, [& @& r, f* F7 @4 p! r' c' G7 G2 [- N& E
Table 1. Example of MRI labeling information for a medical implant or device.
- r- J5 L5 {0 U) O7 X8 ]2 c4 VMRI Information
1 O% H" T- A( U! T' f& B
6 F* n. F5 o$ P7 i. t/ [
Non-clinical testing has demonstrated the Example Implant is MR Conditional. It can be scanned safely under the following conditions: 4 N2 w7 m) Q( y( ]- a8 y7 t" w% G
9 B3 K7 K+ i  @+ U) ~8 ^% B9 D-Static magnetic field of 3-Tesla.1 w: u0 q7 i4 Y8 p! L+ c3 g7 D
( r) s4 b; |* f" b7 H; Q-Spatial gradient magnetic field of 720-Gauss/cm or less.
& u$ V# y8 H1 ~( |& o1 _- U3 T1 V( R3 r8 _5 L* x" J
' g9 b, K) \. c, X9 R/ J; W5 f4 U" [6 U9 o! h$ \8 n
-In non-clinical testing, the Example Implant produced a temperature rise of less than 2.0°C at a maximum MR system reported, whole body averaged specific absorption rate (SAR) of 2- W/kg for 15 minutes of MR scanning in a (static magnetic field strength ________) (model ______) (MR system manufacturer ________) (software version _______) MR scanner. 7 ]6 h& O' B& ~! v# L( q
" C- V; K  t% _8 i. ]9 e! u1 ]Image Artifact: L+ ^+ `, W' ^+ g" ]9 a+ w
MR image quality may be compromised if the area of interest is in the same area or relatively close to the position of the device. Therefore, it may be necessary to optimize MR imaging parameters for the presence of this implant.6 y8 U/ J  [' w6 [" j. x2 R
  w" S9 V) t2 K! _6 M( _& C
Summary and Conclusions, v$ p4 e9 }+ [% n
This Editorial presents current FDA recommendations for MR safety terminology and labeling for implants and other medical devices and provides an explanation of how this information may be applied. Notably, the specific content of the MR labeling may take other forms (especially for electrically active implants and devices) as the format continues to be refined by the FDA in an ongoing effort to properly communicate this information to ensure patient safety. 9 z3 E& v- d9 B7 i
* i. C( P: Q0 x3 |. NREFERENCES/ e" S; C2 ~. |5 l% a
(1) Shellock FG, Crues JV. MR procedures: biologic effects, safety, and patient
' c: w/ S# s; e/ Ccare. Radiology, 2004; 232:635-652.4 L* B, J+ j! V+ r5 m: ]  L4 E1 Q
(2) Shellock FG. Reference Manual for Magnetic Resonance Safety Implants and Device: 2010 Edition. Biomedical Research Publishing Group, Los Angeles, CA, 2010.
" u5 P8 s" e5 ?1 e- o2 p; m: j(3) Shellock FG, Spinazzi A. MRI Safety Update: 2008, Part 2, Screening patients for MRI. American Journal of Roentgenology 2008;191:12-21.: `9 D4 V. P$ }
(4) Woods TO. Standards for medical devices in MRI: present and future. J Magn Reson Imaging. 2007; 26:1186-9.- m0 h2 O4 f7 n. }' z! V. Y
(5) Levine GN, Gomes AS, Arai AE, Bluemke DA, Flamm SD, Kanal E, Manning WJ, Martin ET, Smith JM, Wilke N, Shellock FG. Safety of magnetic resonance imaging in patients with cardiovascular devices: an American Heart Association Scientific Statement from the Committee on Diagnostic and Interventional Cardiac Catheterization. Circulation 2007; 116:2878-2891.
% ~5 o9 c" G  a+ H7 [' Y(6) United States Food and Drug Administration, Center for Devices and Radiological Health, A Primer on Medical Device Interactions with Magnetic Resonance Imaging Systems. http://www.fda.gov/cdrh/ode/primerf6.html, 1997.# @) k; E* H$ P) {7 F4 I& {
(7) American Society for Testing and Materials (ASTM) International, Designation: ASTM F2052 - 06e1, Standard Test Method for Measurement of Magnetically Induced Displacement Force on Medical Devices in the Magnetic Resonance Environment. ASTM International, West Conshohocken, PA.  X: Y) r' Z% u1 V4 H! v
(8) American Society for Testing and Materials (ASTM) International, Designation: ASTM F2213-06, Standard Test Method for Measurement of Magnetically Induced Torque on Medical Devices in the Magnetic Resonance Environment. ASTM International, West Conshohocken, PA.
& f& _  b! z# g6 ~7 _(9) American Society for Testing and Materials (ASTM) International, Designation: ASTM F2119 – 07, Standard Test Method for Evaluation of MR Image Artifacts from Passive Implants. ASTM International, West Conshohocken, PA.
% @7 T# |. M4 x/ Z1 r6 y( p(10) American Society for Testing and Materials (ASTM) International, Designation: ASTM F2182 - 02a, Standard Test Method for Measurement of Radio Frequency Induced Heating Near Passive Implants During Magnetic Resonance Imaging. ASTM International, West Conshohocken, PA.
% Z: v8 E* W( ^2 R. t6 y(11) Guidance for Industry and FDA Staff - Establishing Safety and Compatibility of Passive Implants in the Magnetic Resonance (MR) Environment. Document issued on: August 21, 2008; http://www.fda.gov/cdrh/osel/guidance/1685.html
6 P0 w+ K6 e7 X(12)Shellock FG, Crues JV. Commentary: MR safety and the American College of Radiology White Paper. American Journal of Roentgenology 2002; 178:1349-1352.
: [  K. I* p& P* X(13) American Society for Testing and Materials (ASTM) International, Designation: F2503-08, Standard Practice for Marking Medical Devices and Other Items for Safety in the Magnetic Resonance Environment. ASTM International, West Conshohocken, PA.
, p* ~) k& f9 k, `- I. Q(14) http://www.mrisafety.com/ accessed June, 2010.
  F& a2 K& |; `+ e* h  a3 g
发表于 2013-1-8 15:11:18 | 显示全部楼层
楼主在考大家英文水平9 H& T+ f3 x1 X9 F7 ~* d
发表于 2013-11-4 16:42:24 | 显示全部楼层
什么是MR?
: ~1 X. G6 Z4 @& f7 }9 C3 T
 楼主| 发表于 2013-11-4 20:15:58 | 显示全部楼层
汉宫青鸟 发表于 2013-11-4 16:42
: W* i' b: u/ r/ h2 w什么是MR?
3 [1 b0 L' X5 v0 W/ g# D/ `7 h
Magnetic resonance 磁共振
) ~% J, ]1 ?) `. L: t9 G+ I
发表于 2013-11-6 16:17:52 | 显示全部楼层
andyany 发表于 2013-11-4 20:15
7 h, ?8 }4 i5 D3 r7 w- qMagnetic resonance 磁共振
# h% Z0 T4 _4 t; @哦  晓得了 ,你有认识北京做机加工比较好的厂子吗?我有一个非标准的弹簧垫圈要做,国内貌似都没好的。
. y% E6 V$ g& D0 N5 ?
发表于 2014-7-8 11:31:24 | 显示全部楼层
我们最近在做一个核磁共振的医疗床。不过楼主的文章得请个翻译了!
 楼主| 发表于 2014-7-8 12:02:42 | 显示全部楼层
张超518 发表于 2014-7-8 11:31 8 a6 w7 u" S9 K8 o! x& D$ Z
: P0 o* Q5 L  j. e+ A- ]我们公司有翻译,其他同事的文件都找她翻译。我从不找她。
& ]# s7 p" t9 u. f) w! h9 \2 D自己干,兄弟。拿下他!
$ Z! e% r& P. Q1 a
GMT+8, 2025-6-16 13:03 , Processed in 0.069400 second(s), 18 queries , Gzip On.
