chenyin593 发表于 2006-12-19 16:31:25
压缩做功独立室旋转活塞发动机
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 39pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 39.0pt"><SPAN lang=EN-US style="mso-fareast-font-family: 'Times New Roman'"><SPAN style="mso-list: Ignore">本人设计了一种旋转发动机方案,具有以下特点:</SPAN></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 39pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 39.0pt"><SPAN lang=EN-US style="mso-fareast-font-family: 'Times New Roman'"><SPAN style="mso-list: Ignore">1、<SPAN style="FONT: 7pt 'Times New Roman'">&nbsp; </SPAN></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">采用旋转活塞,由作功介质直接推动轴而输出扭矩;</SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 39pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 39.0pt"><SPAN lang=EN-US style="mso-fareast-font-family: 'Times New Roman'"><SPAN style="mso-list: Ignore">2、<SPAN style="FONT: 7pt 'Times New Roman'">&nbsp; </SPAN></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">采用进气压缩、预燃、作功排气三个定时连通的容腔来完成热力循环,实现膨胀容积大于压缩容积,提高效率;</SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 21pt"><SPAN lang=EN-US style="mso-fareast-font-family: 'Times New Roman'"><SPAN style="mso-list: Ignore">3、<SPAN style="FONT: 7pt 'Times New Roman'">&nbsp; </SPAN></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">采用对称结构,作功介质的径向力相互平衡,轴的受力状况接近电动机,结构比往复式简单,材料少;</SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 39pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 39.0pt"><SPAN lang=EN-US style="mso-fareast-font-family: 'Times New Roman'"><SPAN style="mso-list: Ignore">4、<SPAN style="FONT: 7pt 'Times New Roman'">&nbsp; </SPAN></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">用进排气口结构,省去了往复式的进排气阀及驱动机构,噪音也降低了;</SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 39pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 39.0pt"><SPAN lang=EN-US style="mso-fareast-font-family: 'Times New Roman'"><SPAN style="mso-list: Ignore">5、<SPAN style="FONT: 7pt 'Times New Roman'">&nbsp; </SPAN></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">燃料可采用催化桶形燃烧,燃烧完全,排放好;</SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 39pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 39.0pt"><SPAN lang=EN-US style="mso-fareast-font-family: 'Times New Roman'"><SPAN style="mso-list: Ignore">6、<SPAN style="FONT: 7pt 'Times New Roman'">&nbsp; </SPAN></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">可变进气量、可变余隙容积,在发动机的各种工况,保证压缩终点的温度在最佳点上,发动机的运行经济性提高了,排气的</SPAN><SPAN lang=EN-US>NOX</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">也少了;</SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 39pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 39.0pt"><SPAN lang=EN-US style="mso-fareast-font-family: 'Times New Roman'"><SPAN style="mso-list: Ignore">7、<SPAN style="FONT: 7pt 'Times New Roman'">&nbsp; </SPAN></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">功率大的发动机可采用中空轴、加上离合器由两台以上的小功率发动机组成,根据工况可选择部分或全部发动机运行,提高了发动机可靠性与经济性,也可用于需要正反转都要输出扭矩的场合(如同轴双螺旋浆);</SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 39pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 39.0pt"><SPAN lang=EN-US style="mso-fareast-font-family: 'Times New Roman'"><SPAN style="mso-list: Ignore">8、<SPAN style="FONT: 7pt 'Times New Roman'">&nbsp; </SPAN></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">该结构用于热气机、压缩机也是种很好的结构。</SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 39pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 39.0pt"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">已经有三维模型图,要进入具体的发动机设计,</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">诚邀有兴趣者加盟.</SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 39pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 39.0pt"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">外型图见附件</SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 39pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 39.0pt">&nbsp;</P>
wdn36409 发表于 2006-12-30 21:09:35
Re: 压缩做功独立室旋转活塞发动机
猜想,
凸出部位为燃烧室,双曲拐四汽缸(四把勺子).
叫内燃机呢?还是外燃机?
请楼主,略加指点.
无线风筝 发表于 2007-1-4 20:27:13
Re: 压缩做功独立室旋转活塞发动机
楼主,听你所说的结构似乎有点像转子发动机的变形
请问你的密封性如何保证呢?
chenyin593 发表于 2007-1-14 21:15:06
Re: 压缩做功独立室旋转活塞发动机
密封需要制造曲线活塞环,这是个很难制造的零件。与三角转子发动机相比,制造难度低,主要要在试验中解决的是密封与散热问题。该发动机属于内燃机。具体的要等半年左右介绍。本人之前的第一个创意见申请号:200610077635.7已经公开
samane 发表于 2007-1-30 14:20:40
Re: 压缩做功独立室旋转活塞发动机
俺看过日本的转缸式发动机,和楼主的很像啊,就是废油
chenyin593 发表于 2007-2-1 17:30:12
Re: 压缩做功独立室旋转活塞发动机
结构:
缸套由两个圆环组成,类似两个轮胎叠在一起、然后沿圆环中心面,分成三部分。旋转活塞在圆环内,弧形隔板将圆环分隔若干个空腔,两圆环之间圆周均布着若干个预燃室分别与两圆环相通,通道上有阀门,阀门与滑块由凸轮驱动,旋转活塞与凸轮同轴。结构上的特殊用文字很难讲述清楚的。
工作原理:
活塞旋转,空气从一圆环的进气孔吸入同时活塞压缩空气,到一定时刻该环与预燃室的阀门打开,空气压入预燃室后阀门关闭。接着燃油喷入预燃室燃烧,燃油着火后,预燃室与另一环的阀门打开,燃气推动另一活塞做功,同时将上一循环的废气排除。
需要详细的联系:chenyin593@163.com
annon 发表于 2010-3-12 23:37:44
有两个问题要考虑
一、压缩比
二、密闭
stoneshi 发表于 2011-2-21 21:13:46
您好,楼主!您的设计我很感谢兴趣。不知道现在进展如何?
chidiandong 发表于 2011-7-1 22:13:22
没有附件下载,真是可惜。
查看完整版本: 压缩做功独立室旋转活塞发动机
