断刀 发表于 2006-10-27 20:08:21
瓦楞纸板加工纸箱其选材和加工工艺
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 10.5pt; tab-stops: 21.0pt"><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'">瓦楞纸板加工纸箱其选材及加工工艺如下:</SPAN><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </FONT></SPAN></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; tab-stops: 15.75pt"><FONT size=3><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman">&nbsp;&nbsp; </FONT></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'">一、瓦楞纸箱的选材见图</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">6-2-1</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'">:评定一个瓦楞纸箱的设计水平高低在于分析它的包装是否合理,有无过分包装现象。首先就是选用构成瓦楞纸箱板的原材料。瓦楞纸箱板的组成材料是根据包装内容物的物品种类、重量、体积及印刷效果等方面来决定。制造瓦楞纸箱板所有原材料有两种,即面纸和芯纸,其中根据原材料的不同,面纸大致可以分为茶板纸和牛皮挂面纸,又因其性质不同可以分成不同的等级,具体内容详见(</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">GB13024---91</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'">国家标准),芯纸即楞纸,具体内容详见(</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">GB13023---91</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'">国家标准)。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><?xml:namespace prefix = v ns = "urn:schemas-microsoft-com:vml" /><v:line id=_x0000_s1031 style="Z-INDEX: 6; LEFT: 0px; POSITION: absolute; TEXT-ALIGN: left" o:allowincell="f" to="207pt,7.8pt" from="198pt,7.8pt"><FONT size=3></FONT></v:line></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><v:line id=_x0000_s1035 style="Z-INDEX: 10; LEFT: 0px; POSITION: absolute; TEXT-ALIGN: left" o:allowincell="f" to="99pt,6.8pt" from="1in,6.8pt"><FONT size=3></FONT></v:line><v:line id=_x0000_s1032 style="Z-INDEX: 7; LEFT: 0px; POSITION: absolute; TEXT-ALIGN: left" o:allowincell="f" to="2in,7.8pt" from="126pt,7.8pt"><FONT size=3></FONT></v:line><v:line id=_x0000_s1036 style="Z-INDEX: 11; LEFT: 0px; POSITION: absolute; TEXT-ALIGN: left" o:allowincell="f" to="180pt,7.8pt" from="126pt,7.8pt"><FONT size=3></FONT></v:line><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes">&nbsp;</SPAN></FONT></SPAN></FONT><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;</SPAN></FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'">特种芯纸(即高强瓦楞纸)</SPAN></FONT><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes">&nbsp; </SPAN></FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'">瓦楞纸箱的选材</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman">&nbsp;&nbsp;&nbsp;&nbsp; </FONT></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'">瓦楞纸板:由箱板纸和通过瓦楞辊加工成波形的瓦楞纸粘合而成的板状物。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 24.5pt"><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'">单瓦楞纸板:由两层箱板纸和一层瓦楞纸加工而成的瓦楞纸,</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 28pt"><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'">双瓦楞纸:由两层箱板纸,两层瓦楞纸和一层夹芯加工而成的瓦楞纸板,见下图</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">6-2-3</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'">:</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><v:shape id=_x0000_s1058 style="MARGIN-TOP: 15.1pt; Z-INDEX: 33; LEFT: 0px; MARGIN-LEFT: 83.25pt; WIDTH: 189pt; POSITION: absolute; HEIGHT: 31.3pt; TEXT-ALIGN: left; mso-position-horizontal-relative: text; mso-position-vertical-relative: text" o:allowincell="f" filled="f" path="m,2hdc39,120,80,212,150,317v10,15,13,39,30,45c242,383,212,368,270,407v61,92,155,132,255,165c540,577,555,582,570,587v15,5,45,15,45,15c659,600,877,626,960,557v14,-12,18,-31,30,-45c1031,462,1037,478,1065,422v7,-14,7,-31,15,-45c1123,300,1181,226,1230,152v9,-13,6,-32,15,-45c1277,59,1328,34,1380,17v146,8,260,-17,375,60c1835,197,1730,52,1830,152v50,50,15,35,45,90c1927,335,1996,423,2055,512v20,31,117,54,135,60c2205,577,2235,587,2235,587v85,-5,174,10,255,-15c2531,560,2550,512,2580,482v90,-90,50,-189,150,-255c2788,141,2901,65,3000,32v100,5,201,2,300,15c3332,51,3387,130,3420,152v29,88,-8,7,60,75c3519,266,3546,323,3585,362v87,87,4,-36,90,75c3697,465,3701,516,3735,527v15,5,45,15,45,15hae" coordsize="3780,626"><v:path arrowok="t"><FONT size=3></FONT></v:path></v:shape><FONT size=3><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman">&nbsp;&nbsp;&nbsp;</FONT></SPAN></SPAN></FONT></P>
<P style="MARGIN-LEFT: 5.25pt"><SPAN lang=EN-US><FONT size=3><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp; </SPAN>按照国标规定,食品用瓦楞纸应使用淀粉黏合剂,或使用具有同等粘合效果的其他黏合剂,决不能使用具有腐蚀性的硅酸钠,判断一个纸箱板是否使用了硅酸钠,首先看纸箱板的面纸与瓦楞纸,芯纸与瓦楞纸之间的粘合处,如有呈现略带黄色,且呈半透明状物,且纸箱板抗压力虽大,但无拉力,易折断;则该纸箱板使用硅酸钠作黏合剂的可能性就很大。</FONT></FONT></SPAN></P>
<P style="TEXT-INDENT: 21pt"><SPAN style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song">根 据所 使 用 瓦 楞 纸 板 的 不 同 、 包 装 内 装 物 的 最 大 重 量 看 其 综 合 尺 寸 是 否 合 理 , 常 见 情 况 见表<SPAN lang=EN-US> 6-2-4 。有 关 标 准 建 议 箱 子 长 宽 之 比 不 大 于<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>2∶5 ∶1<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>; 宽 高 之 比 不 大 于 2∶1 ;并 不 小 于 0.15∶1 。<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></FONT></FONT></SPAN></P>
<P style="TEXT-INDENT: 18.2pt; TEXT-ALIGN: center; mso-char-indent-count: 2.0" align=center><SPAN style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song">表<SPAN lang=EN-US> 6-2-4<SPAN style="mso-spacerun: yes">&nbsp;&nbsp; </SPAN>最大包装重量、综合尺寸和瓦 楞 纸 板的关系<o:p></o:p></SPAN></FONT></FONT></SPAN></P>
<TABLE class=MsoNormalTable style="BORDER-RIGHT: medium none; BORDER-TOP: medium none; MARGIN: auto auto auto 5.4pt; BORDER-LEFT: medium none; BORDER-BOTTOM: medium none; BORDER-COLLAPSE: collapse; mso-table-layout-alt: fixed; mso-border-alt: solid windowtext .5pt; mso-padding-alt: 0cm 5.4pt 0cm 5.4pt; mso-border-insideh: .5pt solid windowtext; mso-border-insidev: .5pt solid windowtext" cellSpacing=0 cellPadding=0 border=1>
<TBODY>
<TR>
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 37.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt" vAlign=top width=50>
<P style="TEXT-ALIGN: center" align=center><SPAN style="FONT-SIZE: 9pt; COLOR: blue; LETTER-SPACING: -0.7pt; mso-bidi-font-size: 10.0pt"><FONT face="宋体, MS Song">种 类<SPAN lang=EN-US><o:p></o:p></SPAN></FONT></SPAN></P></TD>
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ffffff; WIDTH: 75.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=101>
<P style="TEXT-ALIGN: center" align=center><SPAN style="FONT-SIZE: 9pt; COLOR: blue; LETTER-SPACING: -0.7pt; mso-bidi-font-size: 10.0pt"><FONT face="宋体, MS Song">内装物最 大重量</FONT></SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; COLOR: blue; FONT-FAMILY: 'Times New Roman'; LETTER-SPACING: -0.7pt; mso-bidi-font-size: 10.0pt">k</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; COLOR: blue; LETTER-SPACING: -0.7pt; mso-bidi-font-size: 10.0pt"><FONT face="宋体, MS Song">g<o:p></o:p></FONT></SPAN></P></TD>
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ffffff; WIDTH: 66.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=88>
<P style="TEXT-ALIGN: center" align=center><SPAN style="FONT-SIZE: 9pt; COLOR: blue; LETTER-SPACING: -0.7pt; mso-bidi-font-size: 10.0pt"><FONT face="宋体, MS Song">最大综合 尺寸<SPAN lang=EN-US>mm<o:p></o:p></SPAN></FONT></SPAN></P></TD>
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ffffff; WIDTH: 37.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=50>
<P style="TEXT-ALIGN: center" align=center><SPAN style="FONT-SIZE: 9pt; COLOR: blue; LETTER-SPACING: -0.7pt; mso-bidi-font-size: 10.0pt"><FONT face="宋体, MS Song">内装物最 大重量<SPAN lang=EN-US>kg<o:p></o:p></SPAN></FONT></SPAN></P></TD>
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ffffff; WIDTH: 103.05pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=137>
<P style="TEXT-ALIGN: center" align=center><SPAN style="FONT-SIZE: 9pt; COLOR: blue; LETTER-SPACING: -0.7pt; mso-bidi-font-size: 10.0pt"><FONT face="宋体, MS Song">最大综合 尺寸<SPAN lang=EN-US>mm<o:p></o:p></SPAN></FONT></SPAN></P></TD></TR>
<TR style="page-break-inside: avoid">
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #ffffff; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 37.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=50 rowSpan=5>
<P style="TEXT-ALIGN: center" align=center><SPAN style="FONT-SIZE: 9pt; COLOR: blue; LETTER-SPACING: -0.7pt; mso-bidi-font-size: 10.0pt"><FONT face="宋体, MS Song">单<SPAN lang=EN-US><o:p></o:p></SPAN></FONT></SPAN></P>
<P style="TEXT-ALIGN: center" align=center><SPAN style="FONT-SIZE: 9pt; COLOR: blue; LETTER-SPACING: -0.7pt; mso-bidi-font-size: 10.0pt"><FONT face="宋体, MS Song">瓦<SPAN lang=EN-US><o:p></o:p></SPAN></FONT></SPAN></P>
<P style="TEXT-ALIGN: center" align=center><SPAN style="FONT-SIZE: 9pt; COLOR: blue; LETTER-SPACING: -0.7pt; mso-bidi-font-size: 10.0pt"><FONT face="宋体, MS Song">楞<SPAN lang=EN-US><o:p></o:p></SPAN></FONT></SPAN></P>
<P style="TEXT-ALIGN: center" align=center><SPAN style="FONT-SIZE: 9pt; COLOR: blue; LETTER-SPACING: -0.7pt; mso-bidi-font-size: 10.0pt"><FONT face="宋体, MS Song">纸<SPAN lang=EN-US><o:p></o:p></SPAN></FONT></SPAN></P>
<P style="TEXT-ALIGN: center" align=center><SPAN style="FONT-SIZE: 9pt; COLOR: blue; LETTER-SPACING: -0.7pt; mso-bidi-font-size: 10.0pt"><FONT face="宋体, MS Song">箱<SPAN lang=EN-US><o:p></o:p></SPAN></FONT></SPAN></P></TD>
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #ffffff; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ffffff; WIDTH: 75.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=101>
<P style="TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-SIZE: 9pt; COLOR: blue; LETTER-SPACING: -0.7pt; mso-bidi-font-size: 10.0pt"><FONT face="宋体, MS Song">5<o:p></o:p></FONT></SPAN></P></TD>
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #ffffff; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ffffff; WIDTH: 66.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=88>
<P style="TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-SIZE: 9pt; COLOR: blue; LETTER-SPACING: -0.7pt; mso-bidi-font-size: 10.0pt"><FONT face="宋体, MS Song">700<o:p></o:p></FONT></SPAN></P></TD>
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #ffffff; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ffffff; WIDTH: 37.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=50 rowSpan=5>
<P style="TEXT-ALIGN: center" align=center><SPAN style="FONT-SIZE: 9pt; COLOR: blue; LETTER-SPACING: -0.7pt; mso-bidi-font-size: 10.0pt"><FONT face="宋体, MS Song">双<SPAN lang=EN-US><o:p></o:p></SPAN></FONT></SPAN></P>
<P style="TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-SIZE: 9pt; COLOR: blue; LETTER-SPACING: -0.7pt; mso-bidi-font-size: 10.0pt"><FONT face="宋体, MS Song">15<o:p></o:p></FONT></SPAN></P></TD>
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #ffffff; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ffffff; WIDTH: 103.05pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=137>
<P style="TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-SIZE: 9pt; COLOR: blue; LETTER-SPACING: -0.7pt; mso-bidi-font-size: 10.0pt"><FONT face="宋体, MS Song">1000<o:p></o:p></FONT></SPAN></P></TD></TR>
<P style="TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-SIZE: 9pt; COLOR: blue; LETTER-SPACING: -0.7pt; mso-bidi-font-size: 10.0pt"><FONT face="宋体, MS Song">10<o:p></o:p></FONT></SPAN></P></TD>
<P style="TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-SIZE: 9pt; COLOR: blue; LETTER-SPACING: -0.7pt; mso-bidi-font-size: 10.0pt"><FONT face="宋体, MS Song">20<o:p></o:p></FONT></SPAN></P></TD>
<P style="TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-SIZE: 9pt; COLOR: blue; LETTER-SPACING: -0.7pt; mso-bidi-font-size: 10.0pt"><FONT face="宋体, MS Song">1400<o:p></o:p></FONT></SPAN></P></TD></TR>
<P style="TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-SIZE: 9pt; COLOR: blue; LETTER-SPACING: -0.7pt; mso-bidi-font-size: 10.0pt"><FONT face="宋体, MS Song">30<o:p></o:p></FONT></SPAN></P></TD>
<P style="TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-SIZE: 9pt; COLOR: blue; LETTER-SPACING: -0.7pt; mso-bidi-font-size: 10.0pt"><FONT face="宋体, MS Song">1750<o:p></o:p></FONT></SPAN></P></TD></TR>
<P style="TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-SIZE: 9pt; COLOR: blue; LETTER-SPACING: -0.7pt; mso-bidi-font-size: 10.0pt"><FONT face="宋体, MS Song">40<o:p></o:p></FONT></SPAN></P></TD>
<P style="TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-SIZE: 9pt; COLOR: blue; LETTER-SPACING: -0.7pt; mso-bidi-font-size: 10.0pt"><FONT face="宋体, MS Song">2000<o:p></o:p></FONT></SPAN></P></TD></TR>
<TR style="page-break-inside: avoid; mso-yfti-lastrow: yes">
<P style="TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-SIZE: 9pt; COLOR: blue; LETTER-SPACING: -0.7pt; mso-bidi-font-size: 10.0pt"><FONT face="宋体, MS Song">55<o:p></o:p></FONT></SPAN></P></TD>
<P style="TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-SIZE: 9pt; COLOR: blue; LETTER-SPACING: -0.7pt; mso-bidi-font-size: 10.0pt"><FONT face="宋体, MS Song">2500<o:p></o:p></FONT></SPAN></P></TD></TR></TBODY></TABLE>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 15.75pt; tab-stops: 15.75pt"><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'"><FONT size=3>二、<SPAN style="mso-no-proof: yes">瓦楞纸的类型及制造工艺</SPAN></FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 15.75pt; tab-stops: 15.75pt"><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">(一)瓦楞纸的类型</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; mso-char-indent-count: 2.0"><FONT size=3><SPAN lang=EN-US style="mso-no-proof: yes"><FONT face="Times New Roman">1.</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">瓦楞纸箱的瓦楞可分为四种类型:</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><FONT face="Times New Roman">A</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">型,</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><FONT face="Times New Roman">B</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">型,</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><FONT face="Times New Roman">C</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">型,</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><FONT face="Times New Roman">AE</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">型。它们的楞峰高度和每</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><FONT face="Times New Roman">30cm</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">长度上瓦楞个数,在国标</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><FONT face="Times New Roman">GB6544—86</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">中均有规定。</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US style="mso-no-proof: yes"><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp; </SPAN><SPAN style="mso-spacerun: yes">&nbsp;</SPAN>2.</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">各种楞型的特点</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 15.75pt"><FONT size=3><SPAN lang=EN-US style="mso-no-proof: yes"><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes">&nbsp;</SPAN>A</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">型楞特点:单位长度内瓦楞数量最少,楞峰最高,缓冲力大,适用于较轻产品包装箱,但表面</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">印刷效果不太理想。楞高</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><FONT face="Times New Roman">4.5-5mm</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">;楞数</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><FONT face="Times New Roman">34+/-2</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">。</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 15.75pt"><FONT size=3><SPAN lang=EN-US style="mso-no-proof: yes"><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes">&nbsp;</SPAN>B</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">型楞特点:单位长度内瓦楞数量最多,楞峰较小,因而性质与</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><FONT face="Times New Roman">A</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">型楞相反,能承受较大的表面</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">压力,并且印刷效果好,适用于食品类和质地较硬的产品包装箱。楞高</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><FONT face="Times New Roman">2.5-3mm</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">;楞数</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><FONT face="Times New Roman">50+/-2</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">。</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US style="mso-no-proof: yes"><FONT face="Times New Roman"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN>C</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">型楞是介于</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><FONT face="Times New Roman">A</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">型楞和</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><FONT face="Times New Roman">B</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">型楞之间的一种楞型,目前在国内极少采用。楞高</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><FONT face="Times New Roman">3.5-4mm</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">;楞数</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><FONT face="Times New Roman">40+/-2</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">。</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 15.75pt; TEXT-INDENT: 5.25pt"><FONT size=3><SPAN lang=EN-US style="mso-no-proof: yes"><FONT face="Times New Roman">E</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">型楞是美国为取代纸包装而设计的一种有带有“</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><FONT face="Times New Roman">E</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">”字型槽的瓦楞。具有成本极低及印刷效果好</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">等特点,该种楞型纸箱,适用于小包装及精美印刷图案的包装。楞高</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><FONT face="Times New Roman">1.1-2mm</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">;楞数</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><FONT face="Times New Roman">96+/-2</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">。</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><o:p></o:p></SPAN></FONT></P>
<P style="TEXT-INDENT: 27.3pt; mso-char-indent-count: 3.0"><SPAN style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song">(二) 瓦 槽 纸 板箱 制 造 工 艺<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></FONT></SPAN></P>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>1. 瓦 楞 纸 板 生 产 流 水 线 : 它 是 采 用 卷 桶 原 纸 为 原材 料 ,通 过 加 工 形 成 纸 板 , 其 长 度 可 根 据 需 要 用 横 切 机 横 向 切 断 ,纵 向 根 据 需 要 与 瓦 楞 垂 直 方向 完 成 压 痕 线 ,由 此 而 得 的 纸 板 的 特 点 是 表 面 平 整 光 滑 ,印 刷 效 果 好 。<o:p></o:p></FONT></FONT></SPAN></P>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>2.利 用 单 面 机 与 半 机 械 化 工 艺 而 合 成 的 纸 板 ,其 特点 是 瓦 楞 定 型 好 , 无 倒 楞 现 象 。 <o:p></o:p></FONT></FONT></SPAN></P>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>3.半 机 械 化 瓦 楞 纸 板 生 产 工 艺 是 单 机 与 人 工 操 作 相结 合 形 成 工 序 流 程 , 完 成 瓦 纸 的 制 作 。其 特 点 是 适 用 于 小 批 量 生 产 , 且 原 材 料 利 用 率 高 。 <o:p></o:p></FONT></FONT></SPAN></P>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>三、瓦 楞 纸 箱 的 制 造 工 艺 <o:p></o:p></FONT></FONT></SPAN></P>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>(一)瓦 楞 纸 箱 的 制 作 工 艺 包 括 用 瓦 楞 纸 板 制 成 瓦楞 纸<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>箱 的 全 部 工 序 。通 常 是 采 用 设 计 工 艺 对 瓦 楞纸 板 进 行 裁 断 、印 刷 、横 压 线 开 槽 、纵 压 线 、接 合 和 模 切 等 作 业 完 成 ,目 前 根 据 使 用 机 械 的不 同 可分 为 以 下 几 种 工 序 方 式 :<SPAN style="mso-spacerun: yes">&nbsp; </SPAN><o:p></o:p></FONT></FONT></SPAN></P>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>1.裁 断 一 一 横 压 线 一 一 开 糟 一 一 纵 压 线 一 一 印 刷一 一 接 合 <o:p></o:p></FONT></FONT></SPAN></P>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>2. 裁 断 一 一 槽 压 线 一 一 印 刷 一 一 开 槽 一 一 纵 压 线一 一 接 合 <o:p></o:p></FONT></FONT></SPAN></P>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>3. 印 刷 一 一 开 糟 一 一 纵 压 线 一 一 接 合 <o:p></o:p></FONT></FONT></SPAN></P>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>4. 印 刷 一 一 模 切 一 一 接 合 <o:p></o:p></FONT></FONT></SPAN></P>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>(二) 瓦 楞 纸 箱 制 作 技 术 要 求 <o:p></o:p></FONT></FONT></SPAN></P>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>1. 钉 合 瓦 楞 纸 箱 使 用 代 有 镀 层 的 低 碳 扁 丝 , 扁 丝不 应 有 绣 斑 、剥 层 、龟 裂 或 其 他 使 用 上 的 缺 陷 。 <o:p></o:p></FONT></FONT></SPAN></P>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN>2. 粘 合 瓦 楞 纸 箱 使 用 乙 酸 乙 烯 乳 液 或 具 有 相 同 粘 合效 果 的 其 他 粘 合 剂 。 <o:p></o:p></FONT></FONT></SPAN></P>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN>3. 纸 箱 尺 寸 偏 差 见<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>表6-2-5 , 对 于 有 特 定 要 求 的 纸 箱 可 由 供 需 双 方 协 商 制定 。 <o:p></o:p></FONT></FONT></SPAN></P>
<P style="TEXT-INDENT: 9.1pt; mso-char-indent-count: 1.0"><SPAN style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song">表<SPAN lang=EN-US> 6-2-5<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN>纸 箱 尺 寸 偏 差<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>表<o:p></o:p></SPAN></FONT></FONT></SPAN></P>
<TBODY>
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 94.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt" vAlign=top width=126 rowSpan=3>
<P style="TEXT-ALIGN: center" align=center><SPAN style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT face="宋体, MS Song">种<SPAN lang=EN-US><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN>类<o:p></o:p></SPAN></FONT></SPAN></P></TD>
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ffffff; WIDTH: 3cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=113 colSpan=2>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp; </SPAN>1<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>类<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>箱<o:p></o:p></FONT></SPAN></P></TD>
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ffffff; WIDTH: 132.3pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=176 colSpan=2>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>2<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>类<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>箱<o:p></o:p></FONT></SPAN></P></TD>
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ffffff; WIDTH: 4cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=151 colSpan=2>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>3<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>类<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>箱<o:p></o:p></FONT></SPAN></P></TD></TR>
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #ffffff; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ffffff; WIDTH: 37.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=50 rowSpan=2>
<P><SPAN style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT face="宋体, MS Song">单瓦<SPAN lang=EN-US><o:p></o:p></SPAN></FONT></SPAN></P>
<P><SPAN style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT face="宋体, MS Song">楞箱<SPAN lang=EN-US><o:p></o:p></SPAN></FONT></SPAN></P></TD>
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #ffffff; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ffffff; WIDTH: 47.25pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=63 rowSpan=2>
<P><SPAN style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT face="宋体, MS Song">双瓦<SPAN lang=EN-US><o:p></o:p></SPAN></FONT></SPAN></P>
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #ffffff; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ffffff; WIDTH: 132.3pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=176 colSpan=2>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;</SPAN>综合尺寸不大于1000 mm<o:p></o:p></FONT></SPAN></P></TD>
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #ffffff; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ffffff; WIDTH: 4cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=151 colSpan=2>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;</SPAN>综合尺寸不大于1000 mm<o:p></o:p></FONT></SPAN></P></TD></TR>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;</SPAN>单瓦楞箱<o:p></o:p></FONT></SPAN></P></TD>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;</SPAN>双瓦楞箱<o:p></o:p></FONT></SPAN></P></TD>
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #ffffff; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ffffff; WIDTH: 2cm; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=76>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;</SPAN>双瓦楞箱<o:p></o:p></FONT></SPAN></P></TD></TR>
<TR style="mso-yfti-lastrow: yes">
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #ffffff; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 94.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=126>
<P style="TEXT-ALIGN: center" align=center><SPAN style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT face="宋体, MS Song">尺寸偏差<SPAN lang=EN-US><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>mm<o:p></o:p></SPAN></FONT></SPAN></P></TD>
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #ffffff; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ffffff; WIDTH: 37.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=50>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT face="宋体, MS Song">+/-3<o:p></o:p></FONT></SPAN></P></TD>
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #ffffff; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ffffff; WIDTH: 47.25pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=63>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT face="宋体, MS Song">+/-5<o:p></o:p></FONT></SPAN></P></TD>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp; </SPAN>+/-3<o:p></o:p></FONT></SPAN></P></TD>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp; </SPAN>+/-5<o:p></o:p></FONT></SPAN></P></TD>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp; </SPAN>+/-4<o:p></o:p></FONT></SPAN></P></TD>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp; </SPAN>+/-6<o:p></o:p></FONT></SPAN></P></TD></TR></TBODY></TABLE>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>注 :纸 箱 的 综 合 尺 寸 是 指 其 内 尺 寸 长 、 宽 、 高 之和 。其 中1 类 箱 主 要 用 于 出 口 及 贵 重 物 品 的 运 输 包 装 ;2 类 箱 主 要 用 与 内 销 产 品 的 运 输 包 装 ;3 类 箱 主 要 用 于 短 途 、 低 廉 商 品 的 运 输 包 装 。<o:p></o:p></FONT></FONT></SPAN></P>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>4. 箱 体 方 正 ,表 面 不 允 许 有 明 显 的 损 坏 和 污 迹 ,切断 口 表 面 裂 损 宽 度 不 能 超 过 8 mm 。 <o:p></o:p></FONT></FONT></SPAN></P>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>5. 箱 面 印 刷 图 案 文 字 清 晰 、 深 浅 一 致 、 位 置 准 确, 必 须 在 箱 盖 内 印 刷 纸 箱 制 造 厂 名 称 或 代 号 。 <o:p></o:p></FONT></FONT></SPAN></P>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>6. 纸 箱 接 头 钉 合 搭 接 舌 边 宽 度 35-50 mm ,金 属 钉应 沿 着 搭<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>接 部 分 中 线 钉 合 ,采 用 斜 钉 ( 与 纸 箱 立边 成 45度 ) 或 横 钉 ,箱 钉 应 排 列 整 齐 、均 匀 ,钉 距 不 大 于 80 mm ,钉 距 均 匀 ,头 尾 钉 距 底 面 压 痕 边线 不 大 于 20 mm ,钉 合 接 缝 应 钉 牢 、钉 透 ,不 得 有 叠 钉 、翘 钉 ,不 转 角 等 缺 陷 。<o:p></o:p></FONT></FONT></SPAN></P>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>纸 箱 接 头 粘 合 搭 接 舌 边 宽 度 不 小 于 30mn, 粘 合 剂使 用 乙 酸 乙 烯 乳 液 或 具 有 相 同 粘 合 效 果 的 其 他 粘 合 剂 。 粘 合 接 缝 的 粘 合 剂 涂 布 应 均 匀 充 分 ,以 致 面 纸 分 离 时 接 缝 依 然 粘 合 不 分 ,同 时 也 不 应 有 多 余 的 粘 合 剂 溢 出 接 缝 。 <o:p></o:p></FONT></FONT></SPAN></P>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>7. 瓦 楞 纸 箱 的 压 痕 线 宽 度 , 单 瓦 楞 纸 箱 不 大 于 12 mm, 双 瓦 楞 纸 箱 不 大 于 17mm, 折 线 居 中 , 不 得 有 破 裂 断 线 , 箱 壁 不 允 许 有 多 余 的 压 痕 线 。 <o:p></o:p></FONT></FONT></SPAN></P>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>8. 瓦 楞 纸 箱 摇 盖 经 开 合 180<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>度 往 复 5<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>次 以 上 , 3<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>类 箱 板 外 面 层 不 得 有 裂 缝 ,内 面 层 裂 缝 长 度 总 和 不 大 于 70 mm 。 <o:p></o:p></FONT></FONT></SPAN></P>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>9. 瓦 楞 纸 箱 可 根 据 供 需 双 方 的 协 定 进 行 表 面 防 潮处 理 。 瓦 楞 纸 箱 的 机 械 性 能 包 括 抗 压 强 度 , 耐 冲 击 强 度 , 抗 转 载 强 度 等 , 在 每 种 具 体 产 品 用瓦 楞 箱 的 标 准 或 技 术 要 求 中 明 确 规 定 或 由 供 需 双 方 商 定 。 <o:p></o:p></FONT></FONT></SPAN></P>
<P style="mso-outline-level: 1"><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>四、瓦 楞 纸 箱 检 验 标 准 <o:p></o:p></FONT></FONT></SPAN></P>
<P><FONT size=3><FONT face="宋体, MS Song"><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>(</SPAN><SPAN style="COLOR: blue; LETTER-SPACING: -0.7pt; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'">一</SPAN><SPAN style="COLOR: blue; LETTER-SPACING: -0.7pt">) 可根 据 双 方 协 定 进 行 检 验 , 或 按 国 家 标 准 进 行 检 验 , 详 见<SPAN lang=EN-US><SPAN style="mso-spacerun: yes">&nbsp; </SPAN>( GB6543一 86) 。 <o:p></o:p></SPAN></SPAN></FONT></FONT></P>
<P style="TEXT-INDENT: 20.25pt"><SPAN style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song">(二)检验 项 目 大 致 可 以 分 为 以 下 方 面 : 尺 寸 偏 差 、 箱 体 方 正 度 纸 箱 壁 厚 度 、印 刷 、接 合( 钉 合 或 粘 合 )压 痕 线 ,搭 接 舌 宽 度 等 。<SPAN lang=EN-US> <o:p></o:p></SPAN></FONT></FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt"><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes"><FONT size=3>(三)造瓦楞紙箱是否能满足流通所需强度要求</FONT></SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><SPAN style="mso-special-character: footnote-continuation-separator"><FONT face="Times New Roman" size=3> </FONT></P><FONT face="Times New Roman" size=3>
<HR align=left SIZE=1>
</FONT></SPAN></SPAN><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">可有两种方法进行评价瓦楞纸箱是否能满足流通所需强度要求,可有两种方法进行评价:</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><o:p></o:p></SPAN></FONT>
<P></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt"><FONT size=3><SPAN lang=EN-US style="mso-no-proof: yes"><FONT face="Times New Roman">1</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-hansi-font-family: 'Times New Roman'; mso-ascii-font-family: 'Times New Roman'; mso-no-proof: yes">.试验法:在压缩机上对试验样箱按对面、对角、对棱几种不同状态进行挤压,观察其应力应变特性及破损极限。这种方法直观、可靠,但是被动的质量控制手段;</SPAN><SPAN lang=EN-US style="mso-no-proof: yes"><o:p></o:p></SPAN></FONT></P>
<P style="TEXT-INDENT: 20.25pt"><SPAN lang=EN-US style="mso-no-proof: yes"><FONT size=3><FONT face="宋体, MS Song">2.计算法:根据纸箱所用箱板纸及瓦楞原纸的强度,推算出瓦楞纸箱的抗压强度。这是一种经验评估法,简便有效,而且有预测性,因而广泛应用。<o:p></o:p></FONT></FONT></SPAN></P>
<P><o:wrapblock><v:shapetype id=_x0000_t75 filled="f" path="m@4@5l@4@11@9@11@9@5xe" coordsize="21600,21600" stroked="f" o:preferrelative="t" o:spt="75"><v:stroke joinstyle="miter"></v:stroke><v:formulas><v:f eqn="if lineDrawn pixelLineWidth 0"></v:f><v:f eqn="sum @0 1 0"></v:f><v:f eqn="sum 0 0 @1"></v:f><v:f eqn="prod @2 1 2"></v:f><v:f eqn="prod @3 21600 pixelWidth"></v:f><v:f eqn="prod @3 21600 pixelHeight"></v:f><v:f eqn="sum @0 0 1"></v:f><v:f eqn="prod @6 1 2"></v:f><v:f eqn="prod @7 21600 pixelWidth"></v:f><v:f eqn="sum @8 21600 0"></v:f><v:f eqn="prod @7 21600 pixelHeight"></v:f><v:f eqn="sum @10 21600 0"></v:f></v:formulas><v:path o:connecttype="rect" gradientshapeok="t" o:extrusionok="f"></v:path><o:lock aspectratio="t" v:ext="edit"></o:lock></v:shapetype><v:shape id=_x0000_s1059 style="MARGIN-TOP: 53.5pt; Z-INDEX: 34; LEFT: 0px; MARGIN-LEFT: 37.8pt; WIDTH: 129pt; POSITION: absolute; HEIGHT: 31pt; TEXT-ALIGN: left" type="#_x0000_t75"><FONT size=3><FONT face="宋体, MS Song"><v:imagedata o:title="" src="file:///C:\DOCUME~1\GONG~1.LIO\LOCALS~1\Temp\msohtml1\01\clip_image022.wmz"></v:imagedata><?xml:namespace prefix = w ns = "urn:schemas-microsoft-com:office:word" /><w:wrap type="topAndBottom"></w:wrap></FONT></FONT></v:shape></o:wrapblock><BR style="mso-ignore: vglayout" clear=all><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>根 据 中 华 人 民 共 和 国 轻 工 业 部 包 装 公 司 提 出 的 有关 瓦 楞 纸 箱 抗 压 强 度 计 算 如 下 ,以 作 参 考 。<o:p></o:p></FONT></FONT></SPAN></P>
<P style="MARGIN-LEFT: 42.25pt; TEXT-INDENT: -18pt; tab-stops: list 42.25pt; mso-list: l0 level1 lfo1"><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt; mso-bidi-font-family: 宋体"><SPAN style="mso-list: Ignore"><FONT face="宋体, MS Song" size=3>1)</FONT><SPAN style="FONT: 7pt 'Times New Roman'">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN></SPAN></SPAN><SPAN style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song">楞 纸 箱 抗 压 强 度 值<SPAN lang=EN-US> P( Kgf/cm<SUP>2 </SUP>)不 应 小 于 按 下 式 所 得 的 计 算 值 :<o:p></o:p></SPAN></FONT></FONT></SPAN></P>
<P><FONT size=3><FONT face="宋体, MS Song"><SPAN style="COLOR: blue; LETTER-SPACING: -0.7pt">式 中 :<SPAN lang=EN-US>K ---强 度保 险 系 数<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>; G---瓦 楞 纸 箱 所 装 货 物 的 重 量 ( kg );<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>H---堆 码 高 度 ( cm )</SPAN></SPAN><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt; mso-font-kerning: 5.0pt"><o:p></o:p></SPAN></FONT></FONT></P>
<P style="TEXT-INDENT: 26.95pt; mso-char-indent-count: 2.96"><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;</SPAN>h ----箱高 ( cm ); <SPAN style="mso-spacerun: yes">&nbsp;</SPAN><SPAN style="mso-spacerun: yes">&nbsp;</SPAN>s ---箱底面积( cm<SUP>2 </SUP>)<U><o:p></o:p></U></FONT></FONT></SPAN></P>
<P style="TEXT-INDENT: 27.3pt; mso-char-indent-count: 3.0"><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song">2)强 度 系 数 K 根 据 纸 箱 所 装 货 物 的 贮 存 期 和 贮有 条 件 决 定:<o:p></o:p></FONT></FONT></SPAN></P>
<P style="TEXT-INDENT: 27.3pt; mso-char-indent-count: 3.0"><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;</SPAN>贮存 期 小 于30天: K=1.6:<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>贮存 期30-100天 :K=1.65;<SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>贮 存 期100天以上 :K=2<o:p></o:p></FONT></FONT></SPAN></P>
<P style="TEXT-INDENT: 20.25pt"><SPAN style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song">注 :以上抗压 强 度 值<SPAN lang=EN-US>P仅 供 参 考,在 实 际 生 产 中 根 据 所 用 原 材 料 的 不 同,纸 箱 抗 压 强 度 值可能 与 计 算 值 有 一 定 误 差。<o:p></o:p></SPAN></FONT></FONT></SPAN></P>
<P><SPAN lang=EN-US style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song"><SPAN style="mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp;</SPAN></FONT></FONT></SPAN><SPAN style="COLOR: blue; LETTER-SPACING: -0.7pt"><FONT size=3><FONT face="宋体, MS Song"><SPAN lang=EN-US>。 <o:p></o:p></SPAN></FONT></FONT></SPAN></P>
Winter2000 发表于 2006-10-29 16:22:30
Re: 瓦楞纸板加工纸箱其选材和加工工艺
<P><FONT color=#ff0000></FONT><FONT color=#0000ff>瓦楞纸的力量</FONT></P>
<P>德国人超爱用瓦楞纸令我佩服得不得了.</P>
<P><FONT color=#0000ff>1.</FONT>大的可以当摊位的隔间. </P>
<P><FONT color=#0000ff>2.</FONT>小的可以做装饰小羊. </P>
<P><FONT color=#0000ff>3.</FONT>实用的可以做展示台.</P>
<P><FONT color=#0000ff>4</FONT>.复杂一点的可以做目录展示盒. </P>
<P><FONT color=#0000ff>5</FONT>.直接用瓦楞纸作保护书盒,连印刷也一样用单色. </P>
<P><FONT color=#0000ff>6.</FONT>不过最厉害的应该是这一家,连桌子,椅子都是用瓦楞纸做的. </P>
<P><FONT color=#0000ff>7.</FONT>真正有用,连人高马大的德国人都可以坐,一定不是骗人的. </P>
<P>显然瓦楞纸不再是瓦楞纸~ 看完这些照片,对於瓦楞纸的企业是不是有一些啟发呢?</P>
我有瓦楞机平带,片基带
想不到它有这么多用途
<P><FONT style="BACKGROUND-COLOR: #efefef">非常有用的资料,谢谢断大侠!</FONT></P>
楼主,能再和我详细的说一下到底什么是瓦楞么?我有点不是很明白
你找个纸箱,纸箱包装的纸板,里面不是有空心的粘接结构,如半圆型的,是否象瓦片? 瓦楞.
瓦楞分好多型号的:A、B、C、E、F。。,是按瓦楞生产线的瓦楞辊来定的,主要是厚度与峰顶与峰谷的距离不一样来的定,纸板又分三层,五层,七层,一般面纸都加了一些廿油,又跟据瓦楞与瓦楞的组成又分A-B纸,A-E等,纸箱的生产工艺也不同(根据纸箱的具体要求来定)有用原纸“AO”印刷后再成纸板再切断,再做箱的,也有胶印后裱的,这二种是一般印刷质量要求高的,一般水印刷机无法达到要求时,不过现几年一般的纸箱一般都用水墨印刷,一般是先做纸机后印刷再开槽/模切成箱。
sunnyday 发表于 2008-8-2 21:19:40
太有用了,谢谢
:loveliness:
聂俊 发表于 2008-11-27 09:39:15
谢谢断刀大侠的分享,学习了
查看完整版本: 瓦楞纸板加工纸箱其选材和加工工艺
