zkw_1 发表于 2009-4-2 13:36:14
机械密封术语英汉对照表
机械密封术语英汉对照表
1.secondary sealing element辅助密封, 一般指是橡胶材料
2.primary ring动环
3.hardware 结构件
4.mating ring 静环
5.mechanical loading device 一般是指弹簧的材料
1.Type 密封类型
2.direction of the spring 弹簧旋向(RH-右旋,LH-左旋)
3.type of seat 静环形式(例如G9,G6,G60...)
4.combination of material 材料组合
a.rotary ring (primary ring ) 动环
b.stationary ring (mating ring ) 静环
c.secondary mech.seals 辅助密封一般指橡胶
d.spring
e.other l parts
材料代码
1. spring
2. shaft gasket 轴套
3. rotary ring
4. stationary ring
5. stationary gasket 静环垫圈
1.丁晴橡胶 NBR--Nitrile butadiene rubber
2.乙丙橡胶 EPR/EPDM--ethylene propylene rubber
3.氟橡胶 FPM/FKM--fluoroelastomer
4.硅橡胶 MVQ--silicon rubber
5.氯丁橡胶 CR--neoprene/chloroprene rubber
6.氢化丁晴 HNBR--hydrogen NBR
7.全氟橡胶 Kalrez / FFKM --perfluorocarbon rubber
介绍四氟类材料
1.纯聚四氟乙烯 PTFE--polytetrafluoroethylene (Teflon和TEF也可以表达)
2.四氟填充玻璃纤维 glassfibre filled PTFE
3.四氟填充碳纤维 carbonfibre filled PTFE
4.四氟包覆氟橡胶FPM coated PTFE
5.四氟包覆乙丙橡胶 EPDM coated PTFE
6.四氟包覆硅橡胶 MVQ coated PTFE
7.柔性石墨 fexible graphite
国外客户常要的碳化硅(silicon carbide)材料
1.无压烧结碳化硅 sintered pressureless bonded sic (S-SIC)
2.无压烧结碳化硅镶装 shrink-fitted /inserted S-SIC
3.反应烧结碳化硅 sintered reaction bonded sic (R-SIC)
4.反应烧结碳化硅镶装 shrink-fitted /inserted R-SIC
5.表面硅化石墨 surface silicated sic
常用氧化铝材料
1.含99%白色氧化铝.99% AL2O3
2.含95%白色氧化铝.95% AL2O3
3.金属陶瓷cermet
石墨材料
1.浸锑石墨 antimony filled carbon
2.浸巴氏合金石墨 carbon-graphite impregnated babbit
3.浸呋喃树脂石墨 carbon-graphite impregnated Furan resin
4.浸环氧树脂石墨 carbon-graphite impregnated Epoxy resin
5.浸酚醛树脂石墨 carbon-graphite Phenol Aldehyde resin
6.热压石墨,hot pressing carbon graphite
不锈钢--(国外客户经常需要的牌号是304,316,316L)
Ni-resist iron = cast iron--高镍铸铁,现在客人对这个材料需要的比较多
Hast. alloy--合氏合金
AM350--沉淀硬化不锈钢
brass--黄铜
CDMCu--双相钢 (用在铸件上比较多)
械密封各个类型的英文表达方式
我这里列出了34个机械密封分类术语...
1.机械端面密封-mechanical face seal
2.流体动压式机械密封-hydrodynamic mechanical seal
3.切向作用流体动压式机械密封-tangential acting hydrodynamic mechanical seal
4.径向作用流体动压式机械密封-radial acting hydrodynamic mechanical seal
5.流体静压式机械密封-hydrostatic mechanical seal
6.外加压流体静压式机械密封-outside pressurized hydrostatic mechanical seal
7.自加压流体静压式机械密封-self pressurized hydrostatic mechanical seal
8.非接触式密封-non contacting (free contacting) mechanical seal
9.内装式机械密封-internally mounted mechanical seal
10.外装式机械密封-externally mounted mechanical seal
11.弹簧内置式机械密封-mechanical seal with inside mounted spring
12.弹簧外置式机械密封-mechanical seal with outside mounted spring
13.背面高压式机械密封-mecanical seal with high back pressure
14.背面低压式机械密封-mechanical seal with low back pressure
15.内流式机械密封-mechanical seal with inward leakage
16.外流式机械密封-mechanical seal with outward leakage
17.弹簧旋转式机械密封-spring rotating mechanical seal
18.弹簧静止式机械密封-spring standing mechanical seal
19.单弹簧式机械密封-single-spring mechanical seal
20.多弹簧式机械密封-multiple-spring mechanical seal
21.非平衡式机械密封-unbalanced mechanical seal
22.平衡式机械密封-balanced mechanical seal
23.单端面机械密封-single mechanical seal
24.双端面机械密封-double mechanical seal
25.轴向双端机械密封-axial double mechanical seal
26.径向双端面机械密封-radial double mechanical seal
27.串联机械密封-tandem mechanical seal
28.橡胶波纹管机械密封-rubber-bellows mechanical seal
29.聚四氟乙烯波纹管机械密封-PTFE-bellows mechanical seal
30.金属波纹管机械密封-l bellows mechanical seal
31.焊接金属波纹管机械密封-welded l bellows mechanical seal
32.压力成型金属波纹管机械密封-formed l bellows mechanical seal
33.带浮动间隔环的机械密封-mechanical seal with floating intermediate ring
34.磁力机械密封-magnetic mechanical seal
迪斯 发表于 2009-4-3 15:12:38
不错,楼主费心了,大家支持一下
yicheng020 发表于 2009-5-13 15:37:53
对我很有帮助,谢谢楼主
lotus55 发表于 2009-6-17 10:06:53
非常感謝:)
水煎包子 发表于 2009-6-17 18:09:14
:)很不错。LZ辛苦了。我先收藏下来。
mickey 发表于 2009-7-6 11:23:06
我正需要呢 ,楼主辛苦了
lotus55 发表于 2009-7-31 16:28:37
哈,這個好,謝謝了:)
tong051 发表于 2009-12-14 14:39:03
好资料,顶一下。
酷魁 发表于 2012-7-12 23:23:11
thanks a lot . it very usefully for me .
朱雀oo 发表于 2012-7-12 23:41:16
{:soso_e142:}支持 谢谢楼主 费心 哈哈
查看完整版本: 机械密封术语英汉对照表
