一往冇前 发表于 2024-1-9 09:33:50
拧螺丝竟然有这么多学问!
为大家分享一些与螺栓拧紧相关的知识。不要小看拧螺丝,螺栓连接是作用巨大,其中涉及一些重要的理论知识,千万不可忽视哦。https://p7.itc.cn/q_70/images03/20231208/856dd45e882e4a299745b6e07b25d361.jpeghttps://p5.itc.cn/q_70/images03/20231208/680c374ff23540788d8642b59a56fd31.jpeghttps://p2.itc.cn/q_70/images03/20231208/29c6b447073a48a58fe5e11fe456bd14.jpeghttps://p6.itc.cn/q_70/images03/20231208/08009acd6ee74960a4edb1d84bb16b3a.jpeghttps://p4.itc.cn/q_70/images03/20231208/e2dfea1ad1354ae7b3997f0bbc43b203.jpeghttps://p7.itc.cn/q_70/images03/20231208/9ebee930154e4f9ea5b52a42e0451a06.jpeghttps://p3.itc.cn/q_70/images03/20231208/30737af26fdc4c90bf3583c3b14375e0.jpeghttps://p5.itc.cn/q_70/images03/20231208/f2dc920f08374c489e15eabe76e844e1.jpeghttps://p3.itc.cn/q_70/images03/20231208/1eecf0ecee204e5ebfe3a0259d5c329e.jpeghttps://p1.itc.cn/q_70/images03/20231208/44f796ea59e94429a2ddf9dafcc3cc02.jpeghttps://p9.itc.cn/q_70/images03/20231208/6a46d15fcd4e4643ba29a28a5cfd36ff.jpeghttps://p8.itc.cn/q_70/images03/20231208/c20155523e3c4b6798c19ef3c09cdbda.jpeghttps://p3.itc.cn/q_70/images03/20231208/80db13636ba24604bc515d280fe71726.jpeghttps://p9.itc.cn/q_70/images03/20231208/579edd31ad7944c49a85254128979519.jpeghttps://p8.itc.cn/q_70/images03/20231208/624c0b57a43845d0845f687d7c6d832f.jpeghttps://p1.itc.cn/q_70/images03/20231208/45ad30bd6ace43eb882260ece6b3dd97.jpeghttps://p1.itc.cn/q_70/images03/20231208/1ca7ea1ca3294d7ba0dc22a8f6a1a5a1.jpeghttps://p0.itc.cn/q_70/images03/20231208/ca17f8fca734484fbc3bfd3bcbaceffa.jpeghttps://p1.itc.cn/q_70/images03/20231208/7eb98f0eb0a94a47b3967e90875f7711.jpeghttps://p7.itc.cn/q_70/images03/20231208/04bb9b4fdade498f9fb4c86f0938206f.jpeghttps://p4.itc.cn/q_70/images03/20231208/f29725e0b106498387c056905cb1ef12.jpeghttps://p0.itc.cn/q_70/images03/20231208/5c2987cd420e4c9fa4f15e8c8e509860.jpeghttps://p4.itc.cn/q_70/images03/20231208/5063a3a86cbe4e04b0d5295a7b5b102a.jpeghttps://p3.itc.cn/q_70/images03/20231208/b8322a3b66314b6b9b52ce52e544b0d5.jpeghttps://p8.itc.cn/q_70/images03/20231208/31c461dc65e74509a8fd021ecbb56f77.jpeghttps://p6.itc.cn/q_70/images03/20231208/0aba239bed194b5888883bbd7fd3cd70.jpeghttps://p3.itc.cn/q_70/images03/20231208/d9bd5e655f684401b4f8cbe2c8a567eb.jpeghttps://p1.itc.cn/q_70/images03/20231208/30f242f517224fdabfdc0c5843bf70e5.jpeghttps://p0.itc.cn/q_70/images03/20231208/d852a1a1f7714b2a94451e1b54cda4a2.jpeg拧紧技术中的螺栓/螺母的失效螺栓拧紧是装配环节的重要环节,螺栓/螺母在产品寿命周期内必须稳定连接,否则有可能造成严重的质量事故,因为螺栓/螺母失效而导致的安全事故时有发生。螺栓/螺母的失效方式有以下几种:1. 强度不足螺栓常见强度等级如下,如果螺栓制造商供应的螺栓不能满足对应的强度要求,螺栓连接的安全性也无法得到保障。https://p6.itc.cn/q_70/images03/20231208/6ab283e73e054f43a59c0989c6a8e5b5.png2. 螺纹副强度不足按照ISO898要求,与螺栓配合的螺纹副/螺母强度要与螺栓本身强度相匹配,比如螺栓强度为10.9的螺栓,应采用强度为10的螺母。https://p8.itc.cn/q_70/images03/20231208/d621257a0d124eee8968fd76a85b0f9c.png3. 螺纹副高度同样根据ISO898要求,螺母或者有效螺纹连接高度一般大于公称直径D的0.8以上,比如M10的螺栓与之匹配的螺母高度不得低于8mm。螺栓/螺母机械强度测试螺栓/螺母机械强度的测试方法很多,比较权威的方法是依据ISO898-1以及ISO898-2,对于螺栓的机械抗拉强度测试方法如下:固定螺栓两端,通过万能材料试验机产生轴向拉力,通过轴向拉力/轴向拉伸量获得螺栓的机械性能指标。https://p2.itc.cn/q_70/images03/20231208/795d2b3ad7ea4bea870b60e05b726760.jpeg轴向拉力/轴向拉伸量:https://p9.itc.cn/q_70/images03/20231208/17796cdadd984bd7b994fd538e7644b6.png螺母/螺纹副的机械强度测试,如下图示意:https://p3.itc.cn/q_70/images03/20231208/8e0eea86afcd4612a314859e41bfe356.png1)实验载荷一般抗拉强度为88%~94%;2)持续载荷15s;3)需确保螺杆没有永久变形;4)15s后手动可以将螺纹旋出,则表示螺母/螺纹副强度合格。小贴士:螺栓/螺母的失效形式有:滑牙、疲劳失效、涂层失效、螺纹副脱落、电化学腐蚀、拉断、剪断和过度衰减等。
babty 发表于 2024-1-9 09:43:37
确实不简单。
bravo090 发表于 2024-1-9 09:46:53
扭到螺栓快失效去?
芙蓉江璐 发表于 2024-1-9 10:34:55
感谢楼主科普。
一般应用工况使用普通螺栓,只要强度够都没问题,震动大的加自锁垫圈。
高压,耐腐蚀的工况,会使用特种材料螺栓螺母,预热高温后紧固连接。
高温,高转速的工况,会采用液压螺栓,压夜螺母之类的特殊紧固连接。
江苏阿虎wyh 发表于 2024-1-9 10:53:30
非常感谢楼主的分享!
热青茶 发表于 2024-1-9 13:27:54
一问干什么的。打螺丝的。
说你螺丝都打不好,一点不为过。:)
测绘工 发表于 2024-1-9 14:03:42
为啥要学这个,让老板买法兰面冷镦自锁螺母不香吗
LGP1 发表于 2024-1-9 14:19:43
感谢分享
mhfx2020 发表于 2024-1-31 10:43:13
感谢分享
查看完整版本: 拧螺丝竟然有这么多学问!
